Results 11 to 20 of 39
02-08-2013, 09:11 PM #11Elite Member
- Join Date
- Jan 2009
- Posts
- 2,709
- Location
- Figuring the picking points of jelly donuts.
- Tractor
- John Deere, 4200
Re: Grind the bevel off weldable hooks?
Teikas Dad did you see this thread I started about Mig weld testing?
http://www.tractorbynet.com/forums/w...reak-test.html
Here is a good calculator by Miller, I suggest you bookmark it.
Miller - Welding Calculators
02-08-2013, 09:21 PM #12Silver Member
- Join Date
- Aug 2012
- Posts
- 162
- Location
- In a city in a state
- Tractor
- Kubota B3200
Thanks Carl. When I do my practice welds I'll beat up a couple and take some before and after photos.
I took a look at the Miller link. With the 187 am I able to do spray or is that strictly a short circuit transfer machine?2012 Kubota B3200 FEL/BH w thumb R4
02-08-2013, 11:33 PM #13
You can't get to spray voltages with a 187, even on 220v (if that even has the dual voltage option available?). You need 24-25 V and 200A+ of current, and the 187 appears to top out around 20v. Th calculator is your friend
Miller - MIG Welding Calculator-Dave
"Being a pessimist is great. You can't lose. Either you end up being right...or you are pleasantly surprised."
L3130HST, QA, 723 Loader, 48" Forks, 48" Grapple, Ancient Farmi Skidding winch
Trailer - 10k/16' twin axle w/elec brakes
2005 F250 5.4V8(3V) 3.73/4wd tow vehicle
02-09-2013, 05:09 AM #14Elite Member
- Join Date
- Jan 2009
- Posts
- 2,709
- Location
- Tractor
- John Deere, 4200
Like dstig1 says, I don't think you can get to spray with your machine. I've only played with spray a little bit. From what I understand your only chance might be with 98% argon, and 2% oxygen.
Here is my results with my V350-Pro with 90% argon and 10% Co2. This was with .035" Lincoln L-56 wire. Note the amount of voltage 29.0! It didn't take long until my 200-amp Mig gun was so hot the contact tip was soft!
To be honest with you, for people like us, I don't think spray is worth all the trouble. In a high production shop, yes! For us hobbyist type, nope!
02-09-2013, 05:21 AM #15Elite Member
- Join Date
- Apr 2009
- Posts
- 3,202
- Location
- adirondacks
If I'm not mistaken the bevel is actually there for the weld? Kind of like cutting/grinding a V into big pieces when welding.
02-09-2013, 05:49 AM #16Elite Member
- Join Date
- Jan 2009
- Posts
- 2,709
- Location
- Tractor
- John Deere, 4200
One thing to think about. If you really want to put these hooks on correctly? Is space them up a little. When I built my gooseneck adapter for my trailer. I beveled the vertical beams, but also spaced them up a little.
02-09-2013, 06:48 AM #17
02-09-2013, 05:38 PM #18Silver Member
- Join Date
- Aug 2012
- Posts
- 162
- Location
- Tractor
- Kubota B3200
Thanks all. The bevels stay. Carl, if I read your post correctly in comparison to the photos, are you recommending that I lift the hooks up slightly from the surface I'm going to weld them to? If so, what do recommend, 1/16th or so?
Gotta love this forum....just think how bad I'd screw things up without all of you guys!2012 Kubota B3200 FEL/BH w thumb R4
02-09-2013, 06:06 PM #19Super Star Member
- Join Date
- Nov 2001
- Posts
- 15,678
- Location
- Bethel, Vermont
- Tractor
- John Deere 4400 MFWD
Roy Jackson
A fear of weapons is a sign of retarded sexual and emotional maturity...
02-09-2013, 06:16 PM #20Silver Member
- Join Date
- Aug 2012
- Posts
- 162
- Location
- Tractor
- Kubota B3200
Similar Threads
Weldable Grab Hooks
By Whitey in forum WeldingReplies: 10Last Post: 03-31-2010, 11:19 PM -
JD 790 Bucket Weldable Hooks
By Trails2004 in forum CustomizationReplies: 1Last Post: 01-31-2010, 01:04 PM -
Brake drums-are they weldable?
By digger2 in forum Build-It YourselfReplies: 19Last Post: 12-23-2007, 11:21 PM -
More weldable hooks
By Richard in forum CustomizationReplies: 6Last Post: 04-13-2004, 02:21 PM -
Bucket Hooks Weldable Hooks
By bmac in forum AttachmentsReplies: 1Last Post: 04-18-2003, 10:22 AM
