Results 21 to 30 of 39
02-09-2013, 06:25 PM #21
Re: Grind the bevel off weldable hooks?
You don't have to, it is just a suggestion. It just insures that you get 100 + % penetration. It is a form of open root welding.
Oh I forgot, if you decide to gap the hooks. 1/16" is plenty, or even just use the same wire you will be using to weld the hooks on with. .035"?
02-09-2013, 07:28 PM #22
02-09-2013, 07:53 PM #23
Just a good rule of thumb. Bevel, and gap everything, hard to go wrong when doing those two things.
But, placing a gap, or doing open root welding takes more time to get use to.
02-09-2013, 07:55 PM #24
02-09-2013, 08:06 PM #25
The big problem with Mig welding is, anybody can pick one up and make a very pretty weld. I'll bet you anything, you let me set your machine, and stand over your shoulder for 5-minutes, and I'll have you laying down beautiful welds! Does that mean you're ready to build a trailer by yourself that is gonna be going down the hiway? NO WAY! Most people don't understand how important joint prep is to welding! There is way more to welding, than pulling a trigger on a Mig machine!
02-09-2013, 08:13 PM #26
2009 Kubota M7040, R1s, LA1153 FEL, fork lift, 3 rear remotes, T&T
2002 Kubota L48 TLB, 12", 18", 24" HD buckets
2001 Kubota BX2200, Turf, LA211 FEL
7.5' Howse 3PT disc, 88" Gearmore 4G4 box scraper, 4' box scraper, Gearmore GB85 blade, LandPride RCR2596 cutter, 6', 4' flail mowers, 6', 4' rototiller, 4' Bush Hog cutter, HD subsoiler, Bearcat 70554 chipper, Bush Hog PHD w/ 12", 6" augers, Ford 101 3-bottom plow, 8' land leveler, 6' rake, lots of misc.
02-09-2013, 08:16 PM #27
02-09-2013, 08:27 PM #28
I'm DEFINITELY going to buy a couple extra hooks and practice welding them. I don't stick weld, only MIG so my choices are limited, that's why I want to make sure I do it right. I'd rather go through a couple hooks for practice than do a shoody job welding them on the bucket and have them fail.
2012 Kubota B3200 FEL/BH w thumb R4
02-09-2013, 08:28 PM #29
- Join Date
- May 2012
- Posts
- 2,972
- Location
- Knoxville, TN
- Tractor
- Bobcat CT225
02-09-2013, 08:30 PM #30
- Join Date
- Dec 2012
- Posts
- 203
- Location
- Lucerne, IN
- Tractor
- 53' Allis WD, 54' Allis WD 45, 52' allis CA, Farmall 560, 656 , 47' Deere model A , 38' Deere model A
Weld a good first pass then add another on the bottom toe of that weld. Then one on top of the second weld. Use some scrap pieces to practice on. Check the pics on my post. I pulled out some 30" oaks 50' long from those hooks. Those were even welded with my old Herbert welder!!
Similar Threads
Weldable Grab Hooks
By Whitey in forum WeldingReplies: 10Last Post: 03-31-2010, 11:19 PM -
JD 790 Bucket Weldable Hooks
By Trails2004 in forum CustomizationReplies: 1Last Post: 01-31-2010, 01:04 PM -
Brake drums-are they weldable?
By digger2 in forum Build-It YourselfReplies: 19Last Post: 12-23-2007, 11:21 PM -
More weldable hooks
By Richard in forum CustomizationReplies: 6Last Post: 04-13-2004, 02:21 PM -
Bucket Hooks Weldable Hooks
By bmac in forum AttachmentsReplies: 1Last Post: 04-18-2003, 10:22 AM
