Page 4 of 4 FirstFirst 1234
Results 31 to 39 of 39
  1. #31
    Super Member Shield Arc's Avatar
    Join Date
    Jan 2009
    Posts
    5,994
    Port Orchard, WA.
    John Deere, 4200
    Default Re: Grind the bevel off weldable hooks?
    Quote Originally Posted by gwdixon View Post
    Couldn't agree more. That is why the suggestion of avoiding MIG and going with stick was made earlier.
    One just DOESN'T want those hooks snapping off at an inopportune or critical time.
    Did you see I welded my hooks on with 7018? I'm not afraid of Mig / wire feed, but I've probably run more spools of wire than most here have seen. A Mig welder in the wrong hands does give me concern, that is why I try to help as much as I can.
    Quote Originally Posted by Bday View Post
    Multi pass !!!!!!!!
    You didn't want those hooks to go anywhere did you!
    Miller Dynasty 300.
    Lincoln V350-Pro w/pulse.
    Lincoln LF-74 wire feeder.
    Lincoln SG Spool gun.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    Everlast PowerArc 200ST.
    3 Lincoln SA-200s.
    Vantage 400
    1800 Ellis saw.
    Hypertherm Powermax 1250, CNC table.
    PROFAX Welding Positioner.
    JD2 model 3.
  2. #32
    Epic Contributor RoyJackson's Avatar
    Join Date
    Nov 2001
    Posts
    22,149
    Bethel, Vermont
    John Deere 4520 MFWD, Deere 855D UTV, Z920A Zero Turn Mower and assorted implements
    Quote Originally Posted by Teikas Dad View Post
    I'm DEFINITELY going to buy a couple extra hooks and practice welding them. I don't stick weld, only MIG so my choices are limited, that's why I want to make sure I do it right. I'd rather go through a couple hooks for practice than do a shoody job welding them on the bucket and have them fail.
    Good idea...one can get poor penetration using stick as well as any other type of welding. Personally, I'm partial to TIG welding, but you'd need a big torch for enough heat to weld those hooks.
    Roy Jackson
    "There ain't no such thing as a free lunch..."
  3. #33
    Silver Member Bday's Avatar
    Join Date
    Dec 2012
    Posts
    203
    Lucerne, IN
    53' Allis WD, 54' Allis WD 45, 52' allis CA, Farmall 560, 656 , 47' Deere model A , 38' Deere model A
    Quote Originally Posted by joshuabardwell View Post
    I had the hardest time getting a clean root on those hooks when welding them to a piece of flat stock. The rod was so deep in that I couldn't really see what the puddle was doing.
    Oh Man!!! What a movie?
  4. #34
    Join Date
    Dec 2012
    Posts
    203
    Lucerne, IN
    Hate that when that happens!!!!
  5. #35
    Advertiser kennyd's Avatar
    Join Date
    Jul 2003
    Posts
    12,912
    Westminster, MD
    John Deere 3720 CAB, 455AWS
    Here is one of mine:
    Grind the bevel off weldable hooks?-hook-welds-jpg
    Miller 210, Lincoln L56 .035" wire, 75/25 gas.
    Don't forget to tip the hook slightly away from the first side you tack-the heat will pull it straight, then weld the opposite side.
    KennyD
    www.boltonhooks.com
    Bolt-On Grab HooksTM, Bolt-On Clevis MountsTM, Weld-On Grab Hooks, Specialty Chain and Rigging Accessories, Specialty Hydraulic Components, and MUCH more!
    Visit our YouTube Channel
  6. #36
    Epic Contributor k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    27,428
    Branson, Mo.
    Kioti DK35se Hydrostat
    Here is one of mine.... Stick rules
    Attached Thumbnails Attached Thumbnails Grind the bevel off weldable hooks?-img_20121117_165303_772-jpg   Grind the bevel off weldable hooks?-img_20121117_170314_242-jpg   Grind the bevel off weldable hooks?-img_20121117_165336_859-jpg
    James K0UA
    Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. EA 50 inch single lid "wicked" Grapple. Satisfied Everlast PA160 welder owner NRA Life Member How to add a link to a post . Best way to search TBN .
  7. #37
    Join Date
    Nov 2001
    Posts
    22,149
    Bethel, Vermont
    Quote Originally Posted by k0ua View Post
    Good looking bead, Bro...
    Roy Jackson
  8. #38
    Join Date
    Jun 2009
    Posts
    27,428
    Branson, Mo.
    Quote Originally Posted by RoyJackson View Post
    Thanks Roy, just my little chicom welder you see there at 125 amps some 1/8 inch US Forge 7018 .
    This is on my Kioti, when I looked at the bead, the thought that went through my head was that my bead on the hook looked better than the MIG weld on the the little plate that the Korean guy did.
    James K0UA
    James K0UA
  9. #39
    Join Date
    Nov 2001
    Posts
    22,149
    Bethel, Vermont
    Quote Originally Posted by kennyd View Post
    Good advice and a good lookin' bead, Kenny!!
    I'll admit, I was a pretty decent TIG welder, but I couldn't do crap with MIG or stick!!
    Best thing about being certified on TIG (while I was in the Navy) was it helped me identify good welds...and bad welds.
    Now that I have a pacemaker, welding machines and I aren't a good mix...
    Roy Jackson
Similar Threads
  1. Weldable Grab Hooks
    By Whitey in forum Welding
    Last Post: 04-01-2010, 12:19 AM
  2. JD 790 Bucket Weldable Hooks
    By Trails2004 in forum Customization
    Last Post: 01-31-2010, 02:04 PM
  3. Brake drums-are they weldable?
    By digger2 in forum Build-It Yourself
    Last Post: 12-24-2007, 12:21 AM
  4. More weldable hooks
    By Richard in forum Customization
    Last Post: 04-13-2004, 03:21 PM
  5. Bucket Hooks Weldable Hooks
    By bmac in forum Attachments
    Last Post: 04-18-2003, 11:22 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
