Results 11 to 19 of 19
02-09-2013, 10:31 PM #11Super Member
- Join Date
- Mar 2008
- Posts
- 6,497
- Location
- Northern Fingerlakes region of NY, USA
- Tractor
- Kubota L3830GST, B7500HST, BX2660
Re: Trailer build, my first real MIG welds
If mankind minus one were of one opinion, then mankind is no more justified in silencing the one than the one - if he had the power - would be justified in silencing mankind.
John Stuart Mill
02-09-2013, 10:41 PM #12Silver Member
- Join Date
- Dec 2012
- Posts
- 164
- Location
- Lucerne, IN
- Tractor
- 53' Allis WD, 54' Allis WD 45, 52' allis CA, Farmall 560, 656 , 47' Deere model A , 38' Deere model A
Yah I've seen leather attached to the hood. I've never used it. I think it's more for overhead welding. Sun screen is the best thing to use, but I hate the dust and dirt sticking to everything. At the end of the day you will look pretty rough! I don't have any problem when I'm welding. Just when tacking everything up. They make a cotton sleeve you can buy. Pretty cheap. Just throw aways when there burnt up. They cover from above elbow to wrist.
02-10-2013, 06:17 AM #13Elite Member
- Join Date
- Jan 2009
- Posts
- 2,717
- Location
- Figuring the picking points of jelly donuts.
- Tractor
- John Deere, 4200
As thin as that square tube is, I guarantee you it won't take long until the square tube rips right down the HAZ line.
Here is how I would wrap the flatbar around the square tube. I always liked to heat behind the bend. That way the metal stretches around, and doesn't leave a gap. You end up with a real tight fit, no gaps at the corners.
02-10-2013, 11:02 PM #14Silver Member
- Join Date
- May 2007
- Posts
- 176
- Location
- Castroville, Tx
Just looking at the pic. it looks as if the axel is in the center . It should be2/3 back from the front or you will get a lot of sway when pulling it. Just my idea.
02-11-2013, 08:39 AM #15Super Member
- Join Date
- Mar 2008
- Posts
- 6,497
- Location
- Tractor
It's actually a little back of center. IIRC, its ~31" from the axle center to the back of the deck and ~34" from the axle center to the front of the deck. No plans to run it down the road, just around the farm behind the tractors, golf carts or the RTV so it shouldn't ever get fast enough to sway.
Aaron ZIf mankind minus one were of one opinion, then mankind is no more justified in silencing the one than the one - if he had the power - would be justified in silencing mankind.
John Stuart Mill
02-11-2013, 09:34 AM #16Elite Member
- Join Date
- Jun 2008
- Posts
- 4,735
- Location
- Bismarck Arkansas
- Tractor
- 2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
I hope you also plan to put some diagonal bracing from the tongue to the corners of the trailer as the tongue has little strength as configured in your photos for such a long run. Also on your buttweld splice, I would do a little reinforcing of that joint by laying some reinforcing plate across the butt joint on at least top and one side extending about 3" each side of the weld. Giving the lack of penetration of most MIG welds, I doubt that you have full pen. weld there and a piece of angle iron or 2 pieces of flat bar welded to the joint area would substantially increase the strength.
2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 54" John Deere 332 lawn tractor, 5.5HP rear tined walk behind tiller, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp CC/CV AC/DC welding machine and a shop full of tools that I spend more time looking for than using.
02-11-2013, 10:34 AM #17Super Member
- Join Date
- Mar 2008
- Posts
- 6,497
- Location
- Tractor
I will have to take a picture of the back of it, but as I recall, there was full penetration on the butt weld. We were running the MIG welder about as hot as it would go. We looked at the options and that piece should be stronger than the other piece that I was thinking of putting in there (a piece of 2x2 angle)
On the angle for the tongue, I have pieces some that I may put on there if its needed. As it sits, its stronger than the 4x6 trailers sold at Lowes or Tractor Supply which just have a piece of thin walled 2x2 square stock for the tongue.
John Stuart Mill
02-11-2013, 05:37 PM #18Elite Member
- Join Date
- Jun 2008
- Posts
- 4,735
- Location
- Bismarck Arkansas
- Tractor
You would be surprised how much added strength you get from that diagonal when one side is in tension and other compression. A small lightweight member with diagonals under tension holds a lot more than a straight pieces of heavy tubing.
I assumed by building it yourself that you wanted something better than the 500 # capacity ones at Lowes.2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 54" John Deere 332 lawn tractor, 5.5HP rear tined walk behind tiller, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp CC/CV AC/DC welding machine and a shop full of tools that I spend more time looking for than using.
02-11-2013, 08:31 PM #19Super Member
- Join Date
- Mar 2008
- Posts
- 6,497
- Location
- Tractor
I built it myself mainly because:
1. I wanted a welding project
2. I got everything I have used so far for free (axle/suspension came from a popup camper that the rest of the frame rotted out on, the frame was a chair cart, the back crossbrace was the rail from a garage door opener, the flatstock for the tongue was something that had been kicking around the barn, etc).
3. I wanted something with bigger tires than come on the little trailers from Lowes, etc
I was more or less following the layout of this trailer: Carry-On Trailer - 2,000 lb. GVWR Wood Side Trailer (other than the axle placement) which is rated to carry 1500#
Here is the closeup of the butt joint:
John Stuart Mill
Similar Threads
New trailer build
By saltbranch in forum Trailers & TransportationReplies: 8Last Post: 08-25-2012, 08:19 PM -
gn trailer build
By rec in forum Build-It YourselfReplies: 10Last Post: 01-24-2012, 03:09 PM -
Some trailer build questions
By handirifle in forum Build-It YourselfReplies: 3Last Post: 05-09-2011, 10:57 PM -
and another trailer build
By tatra805 in forum Build-It YourselfReplies: 20Last Post: 01-30-2009, 06:05 PM -
Bad mig welds
By dirt clod in forum Build-It YourselfReplies: 30Last Post: 06-20-2008, 05:30 AM
