Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
  1. #11
    Elite Member Shield Arc's Avatar
    Join Date
    Jan 2009
    Posts
    2,698
    Figuring the picking points of jelly donuts.
    John Deere, 4200
    Default Re: Copper Tig welding.
    Quote Originally Posted by muddstopper View Post
    If it took 150 amps for 1/8in and 300amps for 1/4, does than mean I can do 1/16 with 75amps. Yes this is a real question.
    I played with some 1/16-inch wall pipe this morning. 120-amps seem to work fine to get a puddle going, but again it didn't take long before I was backing out of the pedal.
    Miller Dynasty 300.
    Lincoln V350-Pro w/pulse
    LF-72
    Lincoln SG Spool gun
    Lincoln LN-25.
    Everlast PowerArc 200.
    5 Lincoln SA-200s.
    1800 Ellis saw
    Hypertherm Powermax 1250, CNC table.
    PROFAX Welding Positioner.
    JD2 model 3
  2. #12
    Advertiser Mark @ Everlast's Avatar
    Join Date
    May 2010
    Posts
    1,207
    I wonder what kind of amps you'd need if you preheated. Do they have a flux cleaner for Copper?
    Mark Lugo
    Everlast Welders
    http://www.everlastgenerators.com/
    Need a welder? Give me a call at (877) 755-9353 ext 204!
  3. #13
    Join Date
    Aug 2012
    Posts
    955
    Hartford, SD
    Kubota L3400F
    Quote Originally Posted by Shield Arc View Post
    Very nice!
  4. #14
    Join Date
    Jan 2009
    Posts
    2,698
    John Deere, 4200
    Quote Originally Posted by Mark @ Everlast View Post
    What's that? Educate me!
    Miller Dynasty 300.
    LF-72
    Lincoln LN-25.
    5 Lincoln SA-200s.
    1800 Ellis saw
    JD2 model 3
  5. #15
    Gold Member
    Join Date
    Apr 2006
    Posts
    407
    western NC
    Ventrac, Steiner
    Thats exactly what I was thinking about welding. Got to put together a moonshine still you know.
  6. #16
    Veteran Member deereman75's Avatar
    Join Date
    Apr 2011
    Posts
    1,588
    canada
    Looks good. I don't think I would have bothered ordering proper welding rods though. With how cheap I am, I would have to try it with scrap electrical wire before spending anything.
    "If the women don't find you handsome, they should at least find you handy" - Red Green
  7. #17
    Gold Member
    Join Date
    Apr 2006
    Posts
    407
    western NC
    Ventrac, Steiner
    Wink Re: Copper Tig welding.
    From what I have read, copper wire has a tendency to make a porous weld. Havent tried it so dont know if thats true or not. If true, I think the copper wire wouldnt be a good choice if you where going to do any structual or pressurized pipe welding. For what ever I would be doing, it would be ortamental so I suspect the copper wire would do just fine. Now just where did I put those moonshine still plans.
  8. #18
    Veteran Member dstig1's Avatar
    Join Date
    Apr 2010
    Posts
    1,909
    W Wisc
    Kubota L3130
    I've been following this. Though I have never tried it (on my welding "bucket list") regular copper wire is pretty much pure copper, so it should not cause any problems in a copper weld.... Protected from oxidation by the insulation too, at least to some degree...
    -Dave
    "Being a pessimist is great. You can't lose. Either you end up being right...or you are pleasantly surprised."
    L3130HST, QA, 723 Loader, 48" Forks, 48" Grapple, Ancient Farmi Skidding winch
    Trailer - 10k/16' twin axle w/elec brakes
    2005 F250 5.4V8(3V) 3.73/4wd tow vehicle
  9. #19
    Gold Member
    Join Date
    Jun 2011
    Posts
    464
    kubota L4400
    Default
    Quote Originally Posted by dstig1 View Post
    It works perfect bud, trust me
  10. #20
    Join Date
    May 2010
    Posts
    1,207
    They may not. I've never needed to weld copper. But in brazing and soldering they have it. I would figure that would be something that might help.
    Mark Lugo
    Everlast Welders
Similar Threads
  1. tig welding copper
    By muddstopper in forum Welding
    Last Post: 01-15-2013, 01:19 PM
  2. TIG welding aluminum
    By robs660 in forum Parts/Repairs
    Last Post: 03-22-2011, 08:04 AM
  3. Stainless Tig welding.
    By Shield Arc in forum Welding
    Last Post: 12-11-2010, 02:52 PM
  4. Tig Welding
    By Lazy in forum Welding
    Last Post: 07-17-2004, 09:56 PM
  5. tig welding setup
    By missourihick in forum Welding
    Last Post: 05-19-2004, 05:14 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
