flyerdan
When switching tanks before putting the regulator on, point it in a safe direction and open the valve for a second to give a quick cleaning blast for any debris that might be in the valve pocket. Also, when the regulator / flowmeter isn't hooked to a tank, be careful not to ding the rounded end that goes in the valve, it's a precise machined fit and it doesn't take much to cause a slow leak.
I've ran feeders that have a wirefeed / purge function; basically it's a spring loaded center off toggle switch that will activate the gas solenoid by itself when pushed one way and the drive rollers by themselves the other way. That allows bleeding down the gas pressure without running wire, or making it hot. Also runs wire without gas when changing wire spools. Should be a simple retrofit for someone with a basic electrical knowledge.
