Page 1 of 2 12 LastLast
Results 1 to 10 of 15
  1. #1
    Join Date
    Jan 2006
    Posts
    1,147
    Mass, Northshore, Merrimack Valley
    B6100DT
    Default Arc Welding Stainless Steel
    Has anyone arc welded using 308 SS rods? I have some Blue Demon 308 I got from McMaster-Carr and have a very hard time getting the bead to look nice. It doesn't seem to wet out the base metal very well. And yes, I have tried turning up the heat. It ends up being lumpy and porous looking. The slag is tough to remove also. I saw some threads on Welding Web, Everlast, and Hobart (maybe) where the guys had bad things to say about Blue Demon 7018.
    A guy at work gave me some Blue Lightning rod to try. It's listed as a rod for joining dissimilar alloys. The MSDS lists it as having Iron, Chromium, Nickel, and Manganese in it. So it's kinda like stainless steel. This rod runs easier than the 308 I have. The beads end up looking really nice and smooth and the slag chips off easily too.
    https://www.partsmaster.us/SitePages...?Code=02010311
    Dan C.
    B6100DT, FEL, BH
  2. #2
    Super Member Shield Arc's Avatar
    Join Date
    Jan 2009
    Posts
    6,064
    Port Orchard, WA.
    John Deere, 4200
    Default Re: Arc Welding Stainless Steel
    You are welding on DC, or AC?
    Miller Dynasty 300.
    Lincoln V350-Pro w/pulse.
    Lincoln LF-74 wire feeder.
    Lincoln SG Spool gun.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    Everlast PowerArc 200ST.
    3 Lincoln SA-200s.
    Vantage 400
    1800 Ellis saw.
    Hypertherm Powermax 1250, CNC table.
    PROFAX Welding Positioner.
    JD2 model 3.
  3. #3
    Advertiser Mark @ Everlast's Avatar
    Join Date
    May 2010
    Posts
    2,265
    South GA
    Are you joining steel to steel, stainless to steel, or stainless to stainless? If its stainless to stainless, do you know the classification?
    I've just picked up an unopened 10 lb can of Lincoln red baron 316L MR...for........let's just say cheaper than I should have( Pays to keep your eyes open.) Still not sure what to do with it.
    Need some stainless worth joining now. But the point is, every can of Red Baron I have used (mostly 309L) the slag has chipped or slid right off. I've never tried blue Demon. The only time I had a problem was when I forgot to reset the polarity...and it acted similar to what you describe.
    Mark Lugo
    Everlast Welders
    http://www.everlastgenerators.com/
    Need a welder? Give me a call at (877) 755-9353 ext 204!
  4. #4
    Join Date
    Jan 2009
    Posts
    6,064
    Port Orchard, WA.
    John Deere, 4200
    When I first got my PA-200 I tried some 316L-16 that I've had for around 38-years. Before I could get my hood up the slag was jumping off the weld.
    Attached Thumbnails Attached Thumbnails Arc Welding Stainless Steel-316l-16-jpg   Arc Welding Stainless Steel-lap-1-jpg
    Miller Dynasty 300.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    3 Lincoln SA-200s.
    Vantage 400
    1800 Ellis saw.
    JD2 model 3.
  5. #5
    Join Date
    May 2010
    Posts
    2,265
    South GA
    Can't tell as the brush marks are camouflaging the metal, but is that stainless or were you simply playing around on some less expensive steel?
    Mark Lugo
    Everlast Welders
  6. #6
    Join Date
    Jan 2009
    Posts
    6,064
    Port Orchard, WA.
    John Deere, 4200
    Grind marks? I have no idea what type of stainless steel that is, came off a luggage carousel conveyor.
    Miller Dynasty 300.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    3 Lincoln SA-200s.
    Vantage 400
    1800 Ellis saw.
    JD2 model 3.
  7. #7
    Join Date
    May 2010
    Posts
    2,265
    South GA
    Sorry, I was looking at it on a smaller screen size. It's brush marks. But it is stainless...
    Mark Lugo
    Everlast Welders
  8. #8
    Join Date
    May 2010
    Posts
    2,265
    South GA
    Quote Originally Posted by Mark @ Everlast View Post
    Here's my 20.00 find.
    Attached Thumbnails Attached Thumbnails Arc Welding Stainless Steel-2013-02-27-17-57-a
    Mark Lugo
    Everlast Welders
  9. #9
    Join Date
    Jan 2009
    Posts
    6,064
    Port Orchard, WA.
    John Deere, 4200
    Nice try! But you're getting up there to the age where the eyes are starting to betray you a little bit.
    Miller Dynasty 300.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    3 Lincoln SA-200s.
    Vantage 400
    1800 Ellis saw.
    JD2 model 3.
  10. #10
    Join Date
    Jan 2006
    Posts
    1,147
    B6100DT
    I was using DC. But now can't remember if it was straight polarity or reverse.
    I laid beads on A36 for practice and filled countersunk holes on 303/304? stainless.
    The Blue Lightning rods laid down on A36 looking like ShieldArc's #4 post.
    Dan C.
    B6100DT, FEL, BH
Similar Threads
  1. Stainless Steel MIG welding?
    By texasjohn in forum Welding
    Last Post: 03-25-2013, 08:02 PM
  2. Stainless steel fridge
    By czechsonofagun in forum Related Topics
    Last Post: 01-16-2012, 02:54 PM
  3. gas welding carbon steel to stainless
    By handirifle in forum Welding
    Last Post: 04-11-2011, 01:44 AM
  4. Stainless steel ballustrade wire.
    By alchemysa in forum Rural Living
    Last Post: 11-01-2007, 10:11 AM
  5. Stainless Steel Woodscrews
    By RichZ in forum Related Topics
    Last Post: 01-20-2006, 06:48 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
