Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 22
  1. #11
    Advertiser kennyd's Avatar
    Join Date
    Jul 2003
    Posts
    12,960
    Westminster, MD
    John Deere 3720 CAB, 455AWS
    Default Re: All your welding tips and advice paid off
    Quote Originally Posted by Shield Arc View Post
    My wife has a girl friend who is a rod buster, when ever she stops by I beat her out of a roll or two.
    There are just so many ways you could read that sentence
    KennyD
    www.boltonhooks.com
    Bolt-On Grab HooksTM, Bolt-On Clevis MountsTM, Weld-On Grab Hooks, Specialty Chain and Rigging Accessories, Specialty Hydraulic Components, and MUCH more!
    Visit our YouTube Channel
  2. #12
    Join Date
    Jul 2003
    Posts
    12,960
    Westminster, MD
    Great job TD, super looking welds!
    KennyD
    www.boltonhooks.com
  3. #13
    Super Member Shield Arc's Avatar
    Join Date
    Jan 2009
    Posts
    6,089
    Port Orchard, WA.
    John Deere, 4200
    Quote Originally Posted by kennyd View Post
    OK enlighten me.
    Do you know what a rod buster is?
    Miller Dynasty 300.
    Lincoln V350-Pro w/pulse.
    Lincoln LF-74 wire feeder.
    Lincoln SG Spool gun.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    Everlast PowerArc 200ST.
    3 Lincoln SA-200s.
    Vantage 400
    1800 Ellis saw.
    Hypertherm Powermax 1250, CNC table.
    PROFAX Welding Positioner.
    JD2 model 3.
  4. #14
    Epic Contributor IslandTractor's Avatar
    Join Date
    Sep 2005
    Posts
    21,131
    Prudence Island, RI
    2007 Kioti DK40se HST, Woods BH
    Zip ties will certainly work. Tie wire is so common for me. My wife has a girl friend who is a rod buster, when ever she stops by I beat her out of a roll or two.
    Here is what I was saying about using a strand of wire rope. I'm not use to working with shackles this small. The second picture is more of what I worked with.
    that strand of wire rope is some kind of SERIOUS protection against loss of the bolt. However, how do you get the shackle apart with that thing on there? Do you need to cut it? Looks like you'd need a substantial tool to cut that too.
    Benefit of zip ties is that you can break them with the same screwdriver or point that you will use to loosen the shackle bolt.
  5. #15
    Join Date
    Jan 2009
    Posts
    6,089
    Port Orchard, WA.
    John Deere, 4200
    You only use the wire rope strand if you want the shackle to stay in place on a semi permanent basis. We would do this in the boom tip of cranes. Sometimes we would run out of tail holds in the boom tip, we would cut one eye off a chocker run that end over a sheave not being used, place a wedge socket on the cut off end. And use a shackle to marry the two wedge sockets, and the eye of the choker together. Now in a situation like this you do not want to trust tie wire or a zip tie!
    Miller Dynasty 300.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    3 Lincoln SA-200s.
    Vantage 400
    1800 Ellis saw.
    JD2 model 3.
  6. #16
    Gold Member
    Join Date
    Mar 2012
    Posts
    273
    Chesterfield, VA
    LS3037H
    The latest entry on the List of 10 Things That Sound Dirty But Aren't!
  7. #17
    Join Date
    Sep 2005
    Posts
    21,131
    Prudence Island, RI
    Default
    That makes sense. I've never had Monel tie wire come apart on a shackle but then again I've never had to trust it in serious overhead rigging situations either.
  8. #18
    Join Date
    Jan 2009
    Posts
    6,089
    Port Orchard, WA.
    John Deere, 4200
    In my case the things I dealt with the problem with tie wire and zip ties, another wire rope could rub against the tie wire or zip ties and cut them. When you have this amount of things hanging from the boom tip for months or over a year with out ever coming down you can't run that risk!
    Attached Thumbnails Attached Thumbnails All your welding tips and advice paid off-d-b-seattle-3-jpg
    Miller Dynasty 300.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    3 Lincoln SA-200s.
    Vantage 400
    1800 Ellis saw.
    JD2 model 3.
  9. #19
    Platinum Member Reyer Farms's Avatar
    Join Date
    Sep 2012
    Posts
    655
    Lena, ms
    Mahindra 5010
    Default
    Hey I remember your original thread, your project turned out great! Very fine job.
  10. #20
    Super Star Member daugen's Avatar
    Join Date
    Feb 2012
    Posts
    10,427
    Washington NC (Inner Banks)
    Kubota L5740HSTC3, MF 2615, MF 1230, IH Super A
    wow, that is really impressive. I'm curious about the size of the hooks you used. They are larger than the ones the dealer welded
    onto my FEL, which is a size larger than yours. I was told that's the right size for 3/8 chain. I looked at the small hooks rather skeptically, particularly when my one nice piece of chain won't fit in the smaller hooks.
    As far as the bucket shackle, which I really like, are you pulling anything really heavy with that? Or just lifting?
    I'm clearing downed trees out of the woods and due to inexperience am not sure when the drawbar must be used, or if I can pull
    backwards using the FEL. And a nifty shackle like yours.
Similar Threads
  1. Need tips for welding a gas tank
    By muddstopper in forum Welding
    Last Post: 01-17-2012, 07:02 PM
  2. Stick welding tips?
    By Jarred Hitt in forum Welding
    Last Post: 05-28-2011, 01:23 PM
  3. Welding Tips
    By Silk Hope Soldier in forum Welding
    Last Post: 12-31-2008, 07:05 PM
  4. All The Good Advice Paid Off
    By Iplayfarmer in forum Safety
    Last Post: 08-30-2005, 02:52 PM
  5. welding tips
    By BrettW in forum Welding
    Last Post: 05-19-2003, 03:22 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
