Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 48
  1. #11
    Member
    Join Date
    May 2012
    Posts
    47
    Stanwood, WA
    New Holland T1510
    Default Re: Which MIG wire is the best.
    If you were using C10 gas you might have been in globular transfer which spatters a bunch even compared to short circuit. Like SA said thats a very hot mix.
    A snipit from welding welb
    ESAB University
    and go to the "MIG Welding Handbook".
    starts at
    Handbook - Metal Transfer Variations
    Also check out a lot of the info at the Lincoln site. Tons of info there.
    But with C25, you were not doing spray transfer. C10 or maybe up to C15, you can get spray transfer going, but not C25.
    And not at just 21.6V on 0.035 wire. Transition to spray transfer using 0.035 steel wire is about maybe 23V (C10 or 98-2 Ar-O2) and upwards of 165 amps (98-2) or 180 amps (C10).
    Short-circuit transfer sound : frying/sizzling bacon
    Spray transfer : a hissing sound and lots of heat going on
    Globular transfer : in between and lots of spatter
    Of course if you were using some fancy-schmancy Miller you might have been in pulsed-spray mode. Sound there is sometimes described as "angry bees" (not angry birds ).
  2. #12
    Elite Member dex3361's Avatar
    Join Date
    Aug 2008
    Posts
    3,571
    N. of Charleston WV
    Kubota L4400-1 HST,FEL, 3x3 remotes, TNT. BX1500 54 mmm
    Quote Originally Posted by ChristianHF View Post
    ESAB University
    starts at
    Thanks these look like some good reading. I will bookmark them.
    Randall
    1Timothy Chapter 2:
    3 For this is good and acceptable in the sight of God our Saviour;
    4 Who will have all men to be saved, and to come unto the knowledge of the truth.
    5 For there is one God, and one mediator between God and men, the man Christ Jesus.
  3. #13
    Super Member Shield Arc's Avatar
    Join Date
    Jan 2009
    Posts
    6,014
    Port Orchard, WA.
    John Deere, 4200
    I've had trouble feeding .023 wire before through a 15-feet long gun. I had to make sure the gun was as straight at possible at all times! For sheet metal work you will want C25 gas.
    Miller Dynasty 300.
    Lincoln V350-Pro w/pulse.
    Lincoln LF-74 wire feeder.
    Lincoln SG Spool gun.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    Everlast PowerArc 200ST.
    3 Lincoln SA-200s.
    Vantage 400
    1800 Ellis saw.
    Hypertherm Powermax 1250, CNC table.
    PROFAX Welding Positioner.
    JD2 model 3.
  4. #14
    Join Date
    Aug 2008
    Posts
    3,571
    N. of Charleston WV
    Default
    I checked the gas mix and it's 75/25. I picked up some of the Lincoln L-56 0.30. Then ran some wire and there was a world of difference.
    Which MIG wire is the best.-forumrunner_20130311_204155-png
    This is the first practice plate that is 1/8" thick the first run. It seemed like 20V was a setting that seemed to be where it welded best on 300" a minute and 200" a minute.
    Which MIG wire is the best.-forumrunner_20130311_204213-png
    This is the other side 200IPM 21V 0.30
    Which MIG wire is the best.-forumrunner_20130311_204235-png
    Cranked it up to see what it would do 300IPM 24V 0.30 on the left and the right is 200IPM, 21V, 0.30
    Which MIG wire is the best.-forumrunner_20130311_204311-png
    Thought I would try a little stich welding on 1/16", 16 gauge steel. Te metal I will be welding in will be 18 gauge which is just over 1/20th of an inch.
    Randall
    1Timothy Chapter 2:
  5. #15
    Join Date
    Jan 2009
    Posts
    6,014
    Port Orchard, WA.
    John Deere, 4200
    The first two pictures, looks like you need to turn your wire speed down or your voltage up. Or move faster.
    The one picture with all th BBs, did you change your stick out length? What length of stick out do you use?
    Miller Dynasty 300.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    3 Lincoln SA-200s.
    Vantage 400
    1800 Ellis saw.
    JD2 model 3.
  6. #16
    Join Date
    Jan 2009
    Posts
    6,014
    Port Orchard, WA.
    John Deere, 4200
    Here is some good information about Mig welding put out by Miller.
    Miller - MIG Welding Tips - Intro
    Miller - Making a Sound MIG Weld
    Miller Dynasty 300.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    3 Lincoln SA-200s.
    Vantage 400
    1800 Ellis saw.
    JD2 model 3.
  7. #17
    Join Date
    Aug 2008
    Posts
    3,571
    N. of Charleston WV
    I have the contact tip about flush with the nozzle. Should it be extending out a bit? I didnt change it any time today.
    Randall
    1Timothy Chapter 2:
  8. #18
    Join Date
    Aug 2008
    Posts
    3,571
    N. of Charleston WV
    Quote Originally Posted by Shield Arc View Post
    Thanks I will check these out. Any word of advice on being able to see the puddle better?
    I have my lens setting at 9 and I still cant see like I can stick welding.
    Randall
    1Timothy Chapter 2:
  9. #19
    Join Date
    Jan 2009
    Posts
    6,014
    Port Orchard, WA.
    John Deere, 4200
    What I mean by stick out, is the distance between the puddle and the contact tip. I run about 3/8-inch.
    Sometimes I move the gas nozzle back where the contact tip is sticking out an 1/8-inch or so. Other times I have the contact tip flush with the end of the gas nozzle. A lot of different opinions about this, you'll have to find what works best for you.
    Miller Dynasty 300.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    3 Lincoln SA-200s.
    Vantage 400
    1800 Ellis saw.
    JD2 model 3.
  10. #20
    Join Date
    Jan 2009
    Posts
    6,014
    Port Orchard, WA.
    John Deere, 4200
    Quote Originally Posted by dex3361 View Post
    Go to Wal-Mart or the dollar store, and try on different pairs of reading glasses. May want to measure the distance from your eyes to the conformable welding area. Then when you're at the store hold up something with small print at that same distance. That way you get the correct power of reading glasses. I went through this about 7 or 8 years ago.
    Miller Dynasty 300.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    3 Lincoln SA-200s.
    Vantage 400
    1800 Ellis saw.
    JD2 model 3.
Similar Threads
  1. MIG Wire Corrosion Question
    By Ted Summey in forum Welding
    Last Post: 02-03-2013, 08:12 PM
  2. ??? Mig Amps and Wire speed
    By FredH in forum Welding
    Last Post: 01-31-2013, 07:31 AM
  3. how thick do you weld with your wire feed / mig?
    By lostcause in forum Welding
    Last Post: 05-04-2012, 11:32 PM
  4. What diameter mig wire to use ?
    By timberwolves in forum Welding
    Last Post: 04-27-2012, 05:16 PM
  5. Mig flux core wire
    By SARG in forum Welding
    Last Post: 01-31-2011, 07:50 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
