Page 5 of 5 FirstFirst ... 2345
Results 41 to 48 of 48
  1. #41
    Join Date
    Mar 2013
    Posts
    1,861
    Edmonton, Alberta
    MF 135
    Default Re: Which MIG wire is the best.
    It's still considered welded when all the tacks join together. I think you're confused about different types of welds. If you have a lap joint, you will have a fillet weld but it won't seem like it on thin sheet metal. A butt weld can use a gap and/or a keyhole. Imagine you're welding 1/2" plate instead of 20 gauge for your lap joint and it's easy to see its a fillet weld. A fillet weld is basically a triangle shape weld in a corner or on an edge.
  2. #42
    Elite Member dex3361's Avatar
    Join Date
    Aug 2008
    Posts
    3,571
    N. of Charleston WV
    Kubota L4400-1 HST,FEL, 3x3 remotes, TNT. BX1500 54 mmm
    Yes it will be a fillet weld and a lap joint that is stiched welded all around and stich welded again after it cools to try and keep warpage to a minimum. i wouldnt attempt to but weld this pan. I dont have the tools or skills to get that odd shaped precision cut and matched for a correct but weld. A man has to know his limitations. I have this jeep in about a hundred pieces with the axles out the gas tank off a couple of places cut out of the frame. Changing the gear ratio from 3.07:1 to 4.11:1 and have installed limited slip diffs front(Detroit Tru Trac) and rear(ford 8.8 axle with a Track Lock with carbon fiber clutches). Lot of activity on this old Jeep YJ 1995 model.
    Randall
    1Timothy Chapter 2:
    3 For this is good and acceptable in the sight of God our Saviour;
    4 Who will have all men to be saved, and to come unto the knowledge of the truth.
    5 For there is one God, and one mediator between God and men, the man Christ Jesus.
  3. #43
    Join Date
    Aug 2008
    Posts
    3,571
    N. of Charleston WV
    Default
    Well I started welding the floor pan panel in here is a pic of my horrible mig welds lol
    Which MIG wire is the best.-forumrunner_20130430_133409-png
    Randall
    1Timothy Chapter 2:
  4. #44
    Join Date
    Sep 2012
    Posts
    1,208
    north shore MA.
    Default
    I've seen worse.
    It is a floor pan after all.
    Dan H.
  5. #45
    Super Member
    Join Date
    Aug 2004
    Posts
    6,850
    North of Mtl,Que,Can (Ste Adele)
    MT180D
    Guys, while I am not a body man I have done some panel replacement work, like the complete side of a chevy van as example.
    I borrowed a technique from aviation where we use CLEKO temporary fasteners to align and temporarily fasten panels.
    I overlap the panel and drill a 1/8 hole every 3-4" and fasten with clekos to keep everything in alignment and then proceed to weld contentiously removing the next cleko when I am about an inch or so away.
    The cleko temporary fastener keeps everything in alignment and heat can't distort the panel.
    Oh, and that is with brass and torch. Imagine the great job using wire weld!
    You could also use POP rivets or metal screws to immobilize your panels while welding.
    Naturally those little holes need filling later on.
    A CLEKO is like a tiny pair of fingers that are spring loaded, fit in the hole, grab underneath and pull the two sheets up tight just like a bolt would do.
    They use special pliers to insert and remove. Real fast and easy. You can find on EBay.
  6. #46
    Join Date
    Aug 2008
    Posts
    3,571
    N. of Charleston WV
    Quote Originally Posted by PILOON View Post
    Thanks for the advice. I was able to get a tight fit and the panel to is going in well.
    Randall
    1Timothy Chapter 2:
  7. #47
    Join Date
    Aug 2008
    Posts
    3,571
    N. of Charleston WV
    Quote Originally Posted by CNC Dan View Post
    I've seen worse.
    Just not today.
    Randall
    1Timothy Chapter 2:
  8. #48
    Join Date
    Aug 2008
    Posts
    3,571
    N. of Charleston WV
    Default
    Here is another from this evening. Mind you there is grinding and clean up but it's not coming loose. I weld around and let it cool.
    Which MIG wire is the best.-forumrunner_20130430_223054-png
    Randall
    1Timothy Chapter 2:
Similar Threads
  1. MIG Wire Corrosion Question
    By Ted Summey in forum Welding
    Last Post: 02-03-2013, 07:12 PM
  2. ??? Mig Amps and Wire speed
    By FredH in forum Welding
    Last Post: 01-31-2013, 06:31 AM
  3. how thick do you weld with your wire feed / mig?
    By lostcause in forum Welding
    Last Post: 05-04-2012, 10:32 PM
  4. What diameter mig wire to use ?
    By timberwolves in forum Welding
    Last Post: 04-27-2012, 04:16 PM
  5. Mig flux core wire
    By SARG in forum Welding
    Last Post: 01-31-2011, 06:50 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
