Page 1 of 3 123 LastLast
Results 1 to 10 of 27
  1. #1
    Platinum Member pjbci's Avatar
    Join Date
    Feb 2012
    Posts
    712
    Summit. Ms
    JD 4840, 450j, 310, komatsu D31px22, IH 1486, MF 135, MHF TO35
    Default Vertical Hardsurface suggestions
    I need to make a few vertical welds with some sort of hard surface or wear resistant rods. I want to be able to either stack up the welds or make a big fat bead. I only have an AC welder and vertical is the only position possible. Any suggestions on rods, amps, technique, etc will be greatly appreciated.
  2. #2
    Super Member Shield Arc's Avatar
    Join Date
    Jan 2009
    Posts
    6,017
    Port Orchard, WA.
    John Deere, 4200
    Default Re: Vertical Hardsurface suggestions
    WOW! It's been years since I've done any vertical hard facing, but I seem to remember running it just like 7018. Close arc length, and a little side to side motion.
    Miller Dynasty 300.
    Lincoln V350-Pro w/pulse.
    Lincoln LF-74 wire feeder.
    Lincoln SG Spool gun.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    Everlast PowerArc 200ST.
    3 Lincoln SA-200s.
    Vantage 400
    1800 Ellis saw.
    Hypertherm Powermax 1250, CNC table.
    PROFAX Welding Positioner.
    JD2 model 3.
  3. #3
    Elite Member gwdixon's Avatar
    Join Date
    Jul 2009
    Posts
    3,000
    Northern CA
    Can you get by with just a build up of standard rod or does it HAVE to be hard rod? If you can apply and reapply 7018 AC then that may be the best option.
    The idea with hard rod is to get very little penetration and lay the bead on top of the area. That does not bode well for vertical. All of the rods I use are slow freeze so dripping or sagging is a real issue.
  4. #4
    Join Date
    Feb 2012
    Posts
    712
    Summit. Ms
    Default
    I would like it to be hard but but laying on a thick layer of 7018 would probally be a lot easier. Thats what i did the last couple of times but was looking for a longer lasting weld. May try a little hard surface on top after i build it back up.
  5. #5
    Join Date
    Mar 2007
    Posts
    1,858
    Midwest
    Iseki TA 247. Husqvarna 54",Gravely Zero, Cub Zero,.Polaris 850 ATV's Stihl 018 026 Pro, 029, 034 Super AV, 039, 044 Mag. Stihl Pole Saw.
    Stoody 19. Inexpensive, Most Welding Stores have it Runs AC or DC. More suited for Metal to Earth. If you want Metal to Metal Try 1102. You are on your own going out of position on AC but these will help.
  6. #6
    Join Date
    Feb 2012
    Posts
    712
    Summit. Ms
    Default
    Metal to earth is what i need. Will try it
  7. #7
    Join Date
    Sep 2012
    Posts
    1,208
    north shore MA.
    Default
    build it back up with 7018, then add two layers of hardfacing. I like Lincoln ABR, but have not used it verticle.
    Dan H.
  8. #8
    Join Date
    Feb 2012
    Posts
    712
    Summit. Ms
    Default
    Just an update. The guys at my welding shop didnt have any hardsurface rods that they would reccomend for vertical. They sold me some 7018 110k tensile rods. I was able to get my pos lincoln welder to switch to DC- wouldnt arc on DC+. Anyway i got good results with it. Thanks again for the info guys.
  9. #9
    Join Date
    Mar 2013
    Posts
    1,844
    Edmonton, Alberta
    MF 135
    How can you have DC- and DC+ with an AC machine? I realize it switches back and forth but how the cables are hooked up shouldn't make any difference. Stoody 35 is another good general purpose hardfacing rod. With hardfacing it doesn't matter a whole lot what it looks like. You can use a dot pattern instead of beads too. A 110,000 PSI 7018 would be a 11018. You're better off just hardfacing in the first place. Look on Stoody's website. They might have the technique listed for vertical welding.
  10. #10
    Join Date
    Feb 2012
    Posts
    712
    Summit. Ms
    Default
    Its a lincoln ac/dc machine. Its junk! It has a 3 position switch. Both dc settings have not worked for years so i consider it ac only. Figured corrosion was the problem so i swithed it back an forth a bunch and it started workin in the dc- position. I know i could revere my cables but they are hooked up inside box and i didnt wanna swap em. Im happy with my results. As far as the 7018-110s are concerned i thought the same thing until i saw the box. Then had to show dad the box to get him to believe me. Ha.
Similar Threads
  1. vertical exhaust
    By ggassner in forum Customization
    Last Post: 11-05-2012, 10:43 AM
  2. Vertical Exhaust
    By greene acres guy in forum Customization
    Last Post: 08-01-2010, 10:48 PM
  3. VERTICAL EXHUAST?
    By dirtworksequip in forum John Deere Owning/Operating
    Last Post: 08-02-2006, 05:28 PM
  4. Vertical exhaust
    By rockyridgefarm in forum John Deere Owning/Operating
    Last Post: 09-15-2005, 09:41 PM
  5. Vertical exhaust or not?
    By JSUnlimited in forum Customization
    Last Post: 07-11-2005, 12:42 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
