Page 1 of 3 123 LastLast
Results 1 to 10 of 22
  1. #1
    Elite Member
    Join Date
    Jun 2012
    Posts
    3,808
    Waynesboro Va
    John Deere X310, JD LA 145
    Default Tig or Mig for home hobby shop
    Just wondering the pro's and con's of each as would like both but that is out of the question right now. Have lots done of welding over the years os I don't think skill should be a problem, and speed don't matter much at home. Have not done much welding in the last 20 years so kind of out of date as well. Have made a TPH for a PTO generator, and am making a ballast for the back of my tractor now. Have a little 110 stick welder and want to upgrade. Thanks Ed.
  2. #2
    New Member
    Join Date
    Mar 2013
    Posts
    6
    2013 Kubota L3800DT
    Default
    Sounds like mig might be the way to go. A little blue unit should do you fine. I got 3 mig welders and all 3 are loaded different. My goto unit is a Lincoln 175 loaded with er-70s, no gas. Welds thick metals and can weld in any enviroment. My mm251 and 12vs get used primarily for the heavy fab jobs. Tig is time consuming and the materials super clean. Gas is mandatory and consumables can get costly with different cups, gas lenses, tungsten. But a stack of dimes layed down by a good tighand can't be beat. The mig is more versatile, but get the spool gun option if available.
    Look into the millermatic series, a small 240vac unit should do you just fine.
  3. #3
    Super Member Shield Arc's Avatar
    Join Date
    Jan 2009
    Posts
    6,019
    Port Orchard, WA.
    John Deere, 4200
    Default Re: Tig or Mig for home hobby shop
    I went for years with nothing but a buzz box stick welder, and a Tig rig.
    Miller Dynasty 300.
    Lincoln V350-Pro w/pulse.
    Lincoln LF-74 wire feeder.
    Lincoln SG Spool gun.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    Everlast PowerArc 200ST.
    3 Lincoln SA-200s.
    Vantage 400
    1800 Ellis saw.
    Hypertherm Powermax 1250, CNC table.
    PROFAX Welding Positioner.
    JD2 model 3.
  4. #4
    Epic Contributor k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    27,773
    Branson, Mo.
    Kioti DK35se Hydrostat
    Tig or Mig for home hobby shop-img_20121117_165336_859-jpgTig or Mig for home hobby shop-img_20121117_165303_772-jpgTig or Mig for home hobby shop-picture-015-jpgTig or Mig for home hobby shop-picture-007-jpgTig or Mig for home hobby shop-17v-torch-jpg
    here is mine, a little PA160 by Everlast.. I stick weld with it up to 160 amps with a 60% duty cycle. ( I have never used above 140 though). and I TIG weld with it with a 17V torch and regulator and argon cylinder. Stick for the big stuff, and TIG for the little/thin stuff.
    James K0UA
    James K0UA
    Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. EA 50 inch single lid "wicked" Grapple. Satisfied Everlast PA160 welder owner NRA Life Member How to add a link to a post . Best way to search TBN .
  5. #5
    Join Date
    Sep 2012
    Posts
    1,208
    north shore MA.
    Default
    Quote Originally Posted by marnewelding
    How does that work out.
    Dan H.
  6. #6
    Elite Member
    Join Date
    Jun 2012
    Posts
    3,808
    Waynesboro Va
    Quote Originally Posted by Shield Arc View Post
    I am kind of leaning in that direction but I know MIG has changed a lot after I quit welding for a living.
  7. #7
    Join Date
    Jan 2009
    Posts
    6,019
    Port Orchard, WA.
    John Deere, 4200
    Really it just gets down to the only reason for Mig, is speed. Get a good stick welder, and a Tig rig you should be set. Unless your planning on doing some aluminum work. The things these new inverter welders can do with the puddle is amazing! I'd pitch that 110-volt welder, and get a 220-volt welder. My Everlast PA-200 is very impressive! I wish I would have waited until the PA-300 came out. If I needed another welder the PA-300 would be in my sights. I should take an inventory and see if I need another welder!
    Miller Dynasty 300.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    3 Lincoln SA-200s.
    Vantage 400
    1800 Ellis saw.
    JD2 model 3.
  8. #8
    Elite Member
    Join Date
    Jun 2012
    Posts
    3,808
    Waynesboro Va
    Got to keep the 110 it was a Christmas present from my wife.
  9. #9
    New Member
    Join Date
    Aug 2012
    Posts
    9
    Chicago, IL
    55 Ford 650
    if speed is not a issue then ac/dc tig is the way to go...but I sure do miss my mig for quick tack up work. sure stick can weld dirty metal...but nothing a wire wheel wont clean up. the trade off is keep rods fresh and dry or keeping a tank of argon on hand. I needed ac for aluminun so for me it was a pretty easy choice. Pretty sure I would still have come out better with a tig machine over a stick machine. From what I have seen stick is not so good and working on thinner stuff.
  10. #10
    New Member
    Join Date
    Mar 2013
    Posts
    6
    2013 Kubota L3800DT
    Quote Originally Posted by CNC Dan View Post
    it's the only welder in my shop that stays hooked up other than my synchrowave. I use it for all the small jobs and quick jobs, but have also welded some brackets for a mechanical thumb using it, along with tons of trailer work. i'm a cheapskate and hate turning on gas to make a 3" weld, alot of lost gas if you turning gas off and on.
Similar Threads
  1. MIG or TIG: Which is better?
    By kruss77 in forum Welding
    Last Post: 03-27-2013, 02:35 AM
  2. Tig / Mig / Aluminum / Stainless help
    By woodlandfarms in forum Welding
    Last Post: 03-26-2013, 07:28 AM
  3. Mig - stick - tig multi unit?
    By yarg in forum Welding
    Last Post: 03-21-2013, 10:50 AM
  4. Replies: 14
    Last Post: 06-18-2012, 06:56 PM
  5. Stick, Mig or Tig
    By Sulla in forum Welding
    Last Post: 06-03-2011, 02:52 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
