Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 42
  1. #11
    Join Date
    Dec 2003
    Posts
    120
    UP of michigan
    L48 Kubota
    Default Re: Bandsaws---what type?
    What I know for sure is that my abrasive chop saw will not be my major cut off tool any more! After my first big project, I will not do that sny more.
    If a band saw does all and more than a dry saw, I may put more into the band saw. I am concerned about speed, I am sure it would not be as fast as a dry saw?
    About 1000 if both saws and up to 1400 if just a band saw?
    Gray
  2. #12
    Join Date
    Nov 2008
    Posts
    1,189
    Covington, GA
    JD 870
    One thing nice about a bandsaw is you can start the cut and walk away. Not far away but away. I have a cheap Chinese bandsaw I got that is probably 25-28 years old. It does what I want which is cut metal without a lot of dust, sparks and noise. It is not quiet but it is less loud than an abrasive cut off saw. I would lust after a wet bandsaw if I were a fabricator but the dry one works for the occasional barn door build or other simple 20 cuts project. If I need to do a big project I drive off to my friend's shop that has bigger everything.
  3. #13
    Member
    Join Date
    May 2012
    Posts
    47
    Stanwood, WA
    New Holland T1510
    80 tons SA? Just what the heck are you fabricating over there?
  4. #14
    Join Date
    Dec 2003
    Posts
    120
    UP of michigan
    L48 Kubota
    What is a roll in saw?
    Just googles roll saw and know now.
    I also looked at some reviews and they are not fond of the jet,dake.
    The enco is ok? The grizzly I have not heard about?
    Still no idea of speed vs a cold cut saw?
    Can one do a lot mire than the other?
    Gray
  5. #15
    Super Member Shield Arc's Avatar
    Join Date
    Jan 2009
    Posts
    6,009
    Port Orchard, WA.
    John Deere, 4200
    Quote Originally Posted by ChristianHF View Post
    That was two spreader bars for setting precast concrete utility vaults for the Pier D aircraft carrier pier at PSNS. I had to cut and splice that beam so I could keep the decals in place. That crane is engineered for only 2-tons max.
    Miller Dynasty 300.
    Lincoln V350-Pro w/pulse.
    Lincoln LF-74 wire feeder.
    Lincoln SG Spool gun.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    Everlast PowerArc 200ST.
    3 Lincoln SA-200s.
    Vantage 400
    1800 Ellis saw.
    Hypertherm Powermax 1250, CNC table.
    PROFAX Welding Positioner.
    JD2 model 3.
  6. #16
    Join Date
    Aug 2004
    Posts
    1,922
    Caldwell Co. NC
    2006 Kama554; 92 Belarus 250AS
    Use coupon code 77512189 tomorrow at HF to get this one for $600. http://www.harborfreight.com/1-hp-7-...saw-97009.html
    2006 Kama 554, 92 Belarus 250AS, Bombardier Outlander Max 400.
  7. #17
    Join Date
    Dec 2003
    Posts
    120
    UP of michigan
    L48 Kubota
    Is this HF the same machine as the Enco? It looks very much alike.
    If the motors, and contols are also the same then the HF sells for less.
    Thanks for the heads up,
    The Grizzly is about the same cost for a 6x9.5 with shipping. Anyone know about this machine?
    Gray
  8. #18
    Member
    Join Date
    May 2012
    Posts
    47
    Stanwood, WA
    New Holland T1510
    Quote Originally Posted by Shield Arc View Post
    I somewhat figured, didn't look quite up to 80ton capability but I have to say you have all the cool toys!
    Chris.
  9. #19
    Platinum Member jwmorris's Avatar
    Join Date
    Oct 2007
    Posts
    705
    Just googles roll saw and know now. I also looked at some reviews and they are not fond of the jet,dake.
    The enco is ok? The grizzly I have not heard about? Still no idea of speed vs a cold cut saw? Can one do a lot mire than the other? Gray
    A roll in is semiauto so you just set the feed rate with the counterbalance and gravity does the rest. I added a switch so it cuts off when finished with the cut.;
    It has an offset blade like a horizontal so you can cut any length, unlike most vertical bandsaws.
    Remove the clamp and miter part and you can use it just like a vertical bandsaw.
    I have never used any other brand but did pick up my last one for $500 on Craigslist.
    There is as much difference between "coldsaw" as there are between "bandsaw". You can get coldsaws that are just slower versions of the normal chopsaws (like the little dewalt) up to large 3ph full auto versions that cost $20k+. One thing cold saws have in common with each other are that the blades cost a lot more than bands.
  10. #20
    Veteran Member CliffordK's Avatar
    Join Date
    Mar 2013
    Posts
    1,202
    Eugene, Oregon
    Toro D200, Ford 1715, International 884,
    I finally got a small HF clone bandsaw. 4x6, I think. Used for $100.
    It started throwing blades. I shimmed the rear rollers, and it seems to be ok now.
    Now I wonder how I ever lived without it.
    It cuts dry. It takes a couple of minutes for a cut, but I'm normally doing enough other things that I can wait.
    There are a couple of carbide metal cutting chopsaws that look very sweet, but a bit expensive. But, no doubt they would be a useful cutting tool.
    As far as the rollers, my saw came with a very cheap roller from HF... pretty junky, but certainly useful.
    I picked up a couple of boat trailer bow & keel rollers from the local recycling store, and was going to make them into a roller as I was having lots of problems with the pipe that I was cutting earlier not staying put.
Similar Threads
  1. Rotary Cutter Bush hog 3210... which type semi mount, or trail type?
    By FMRanch in forum Attachments
    Last Post: 02-16-2013, 04:45 PM
  2. Let's talk about bandsaws!
    By TraderMark in forum Welding
    Last Post: 05-08-2012, 12:46 AM
  3. Replace directional valve type tandem by type float
    By hodinhtran in forum Hydraulics
    Last Post: 11-03-2010, 09:01 AM
  4. Disc harrow-3pt type vs drawbar type
    By flusher in forum Attachments
    Last Post: 09-15-2006, 02:29 AM
  5. And Yet Another Type...
    By hobbyfarm in forum ATVs & Utility Vehicles
    Last Post: 06-07-2006, 11:43 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
