Page 1 of 5 1234 ... LastLast
Results 1 to 10 of 42
  1. #1
    Join Date
    Dec 2003
    Posts
    120
    UP of michigan
    L48 Kubota
    Default Bandsaws---what type?
    I have been looking at many options for cutting. I will get a dry cut saw, a plasma cutter but I have been also thinking of a band saw to round out all my needs. I have seen there are wet, dry, horizontal, vertical convertable and swivel head types.
    I am sure I will need an 8" throat but now comes the value options.
    Wet or dry?
    Convertible would be nuke but is it that functional?
    Horizontal for sure.
    Not convinced a swivel head would be needed.
    How fast do they cut?
    Would it be a waist of time to get a dry cut if I get a nice band saw?
    As always, more questions may come up but any information from those who have experience would be helpful.
    Thanks,
    Gray
  2. #2
    Elite Member Rustyiron's Avatar
    Join Date
    Mar 2011
    Posts
    4,255
    Lakes Region, Maine
    M 9540 Kubota
    Default Re: Bandsaws---what type?
    I have a Milwalkie porta-band, it's 30+ y.o. and works great for many cutting jobs but it sounds like you're talking about a stationary saw. Got one of them too and it is a great tool as well. I'd go with the "wet" saw, mine is not but I have no trouble just keeping the cut and guide wheels wet with some wd40 or the like. It does have a good 3" deep pan to add a coolant pump, but in 20 or so years, I just have not gotten around to it. As for the vertical, I would not bother, I have another saw (dedicated vertical) and just do not use it. I am not familiar with the "swevel head" feature. You might start with the porta-band saw first while your looking for a good deal on a nice commercial horiz machine.
  3. #3
    Join Date
    Dec 2010
    Posts
    185
    Love, VA
    Kubota B7100 HST 4WD
    To digress for a second, I also have an ancient Milwaukee portaband, and it is the handiest of all the metal working tools that I have, next to my Evolution chop saw. I buy bands at Home Depot, where I can get two Milwaukee blades for less than one at Northern Tool. I love the thing. And, unless you are a total goober, you can cut very safely with it.
    "For I am not ashamed of the gospel of Christ..." Romans 1:16
    94 Dodge Ram 2500 CTD
  4. #4
    Join Date
    Dec 2003
    Posts
    120
    UP of michigan
    L48 Kubota
    It would be a stationary one as that would be 99% of my work, in shop clean accurate cuts.
    Vertical is not used much? If the unit, like a Jet I saw can convert to vertical, that may allow for the ocational odd shape?
    Wet saw seamed to be the right choice. The only one I ever used was in our HS welding shop and was a wet type.
    It seamed to cut very slow but maybe it was the saw,blade ,or settings?
    More info the better.
    Thanks ,
    Gray
  5. #5
    Super Member Shield Arc's Avatar
    Join Date
    Jan 2009
    Posts
    6,089
    Port Orchard, WA.
    John Deere, 4200
    I had the ENCO version for years, really nice saw. I gave it to a friend when I bought my Ellis. Never once adjusted it.
    Enco - Guaranteed Lowest Prices on Machinery, Tools and Shop Supplies
    G0561 7" x 12" Metal Cutting Bandsaw
    Attached Thumbnails Attached Thumbnails Bandsaws---what type?-thin-cut-1-jpg   Bandsaws---what type?-thin-cut-2-jpg
    Miller Dynasty 300.
    Lincoln V350-Pro w/pulse.
    Lincoln LF-74 wire feeder.
    Lincoln SG Spool gun.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    Everlast PowerArc 200ST.
    3 Lincoln SA-200s.
    Vantage 400
    1800 Ellis saw.
    Hypertherm Powermax 1250, CNC table.
    PROFAX Welding Positioner.
    JD2 model 3.
  6. #6
    Join Date
    Dec 2003
    Posts
    120
    UP of michigan
    L48 Kubota
    Shield arc,
    Do you know annoying about the Grizzly? It's a bit smaller but has the vertical option.
    The enco is a belt change speed? Any more info on that one would appreciated as well.
    Gray
  7. #7
    Join Date
    Jan 2009
    Posts
    6,089
    Port Orchard, WA.
    John Deere, 4200
    Never seen a Grizzly saw, I just added the link for a comparison. I do have a Grizzly Mil.
    The ENCO saw will go vertical too. I always set my metal working tools to the slowest speed and leave them there.
    Miller Dynasty 300.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    3 Lincoln SA-200s.
    Vantage 400
    1800 Ellis saw.
    JD2 model 3.
  8. #8
    Join Date
    Mar 2013
    Posts
    1,861
    Edmonton, Alberta
    MF 135
    I don't know your budget but I saw a saw last week that will cut just about anything. It had a 2 1/2" blade and 43.3" capacity. It was brand new but I didn't ask the price. A swivel head saw is great feature to have. If you have roller stands or even just saw horses to hold long lengths, you don't have to move your feed table when you do angle cuts. The swivel head also has the degrees marked for more accurate cuts and odd angles.
  9. #9
    Join Date
    Jan 2009
    Posts
    6,089
    Port Orchard, WA.
    John Deere, 4200
    Roller stands are only the start, you also need one of these.
    Attached Thumbnails Attached Thumbnails Bandsaws---what type?-assortment-jpg   Bandsaws---what type?-assortment-2-jpg   Bandsaws---what type?-v-stands-jpg   Bandsaws---what type?-hoists-jpg   Bandsaws---what type?-truck-jpg
    Miller Dynasty 300.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    3 Lincoln SA-200s.
    Vantage 400
    1800 Ellis saw.
    JD2 model 3.
  10. #10
    Platinum Member jwmorris's Avatar
    Join Date
    Oct 2007
    Posts
    705
    You need to look at Roll In saws.
Similar Threads
  1. Rotary Cutter Bush hog 3210... which type semi mount, or trail type?
    By FMRanch in forum Attachments
    Last Post: 02-16-2013, 03:45 PM
  2. Let's talk about bandsaws!
    By TraderMark in forum Welding
    Last Post: 05-07-2012, 11:46 PM
  3. Replace directional valve type tandem by type float
    By hodinhtran in forum Hydraulics
    Last Post: 11-03-2010, 08:01 AM
  4. Disc harrow-3pt type vs drawbar type
    By flusher in forum Attachments
    Last Post: 09-15-2006, 01:29 AM
  5. And Yet Another Type...
    By hobbyfarm in forum ATVs & Utility Vehicles
    Last Post: 06-07-2006, 10:43 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
