Page 1 of 3 123 LastLast
Results 1 to 10 of 22
  1. #1
    Elite Member
    Join Date
    May 2012
    Posts
    2,972
    Knoxville, TN
    Bobcat CT225
    Default Scorch/melt on ground clamp
    I noticed a scorched/melted part on my ground clamp today.
    Scorch/melt on ground clamp-img_20130403_134051_577-jpg
    My best guess is that when I had it clamped on the table, the woven copper bridge between the two jaws arced to the table, as shown below.
    Scorch/melt on ground clamp-img_20130403_134135_892-jpg
    It could also be that the woven copper bridge arced to the clamp itself, but that seems unlikely, as it would seem to be an unavoidable design defect, and this is a pretty standard design for a ground clamp.
  2. #2
    Join Date
    Sep 2012
    Posts
    1,208
    north shore MA.
    Default
    yes, if your table is painted or rusty it might not make good contact. I like to twist the clamp back and forth after clamping it on to let the copper jaws rub through any 'gunk' to make better contact.
    Dan H.
  3. #3
    Epic Contributor k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    27,689
    Branson, Mo.
    Kioti DK35se Hydrostat
    Default Re: Scorch/melt on ground clamp
    Yep, that is what happened, I had it happen to me a couple of times too, from not having the contacts on good clean metal, and the braid was touching bare metal.. happened on the lip of a FEL bucket, too much paint further back but the edge where it touched the braid was bare... whoops.
    James K0UA
    Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. EA 50 inch single lid "wicked" Grapple. Satisfied Everlast PA160 welder owner NRA Life Member How to add a link to a post . Best way to search TBN .
  4. #4
    Elite Member
    Join Date
    May 2012
    Posts
    2,972
    Knoxville, TN
    Bobcat CT225
    It's odd, because the "teeth" of the clamp were on clean, bare metal (the table top). But I know that anywhere there's a small gap will arc, so my guess is I shouldn't have put the clamp so deep on the table.
  5. #5
    Elite Member
    Join Date
    May 2012
    Posts
    2,972
    Knoxville, TN
    Bobcat CT225
    I wonder if it would be worthwhile to paint the braided strap with paint-on electrical tape, to prevent this from happening in the future.
  6. #6
    Join Date
    Jun 2009
    Posts
    27,689
    Branson, Mo.
    Quote Originally Posted by joshuabardwell View Post
    That might not be a bad idea. I hadn't thought of that.
    James K0UA
  7. #7
    Elite Member
    Join Date
    May 2012
    Posts
    2,972
    Knoxville, TN
    Bobcat CT225
    Quote Originally Posted by k0ua View Post
    I'm also thinking I may have some heat-shrink that would fit perfectly, which is nice, because I don't currently have any liquid electric tape.
  8. #8
    Elite Member
    Join Date
    May 2012
    Posts
    2,972
    Knoxville, TN
    Bobcat CT225
    I'm not too worried about it, though. Even with half the braid melted through, I would think that the remaining copper should be more than adequate to carry the welding current without excess resistance.
  9. #9
    Elite Member
    Join Date
    May 2012
    Posts
    2,972
    Knoxville, TN
    Bobcat CT225
    Two layers of heat shrink later...
    Scorch/melt on ground clamp-2013-04-03-15-12-a
  10. #10
    Super Member Shield Arc's Avatar
    Join Date
    Jan 2009
    Posts
    6,014
    Port Orchard, WA.
    John Deere, 4200
    I've always had good luck with this kind of ground clamp.
    Tweco Copper Ground Clamp - GC 200
    Miller Dynasty 300.
    Lincoln V350-Pro w/pulse.
    Lincoln LF-74 wire feeder.
    Lincoln SG Spool gun.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    Everlast PowerArc 200ST.
    3 Lincoln SA-200s.
    Vantage 400
    1800 Ellis saw.
    Hypertherm Powermax 1250, CNC table.
    PROFAX Welding Positioner.
    JD2 model 3.
Similar Threads
  1. Ground clamp is hot
    By oliver28472 in forum Welding
    Last Post: 06-04-2012, 01:02 AM
  2. Ground Clamp Differences
    By Haywire in forum Welding
    Last Post: 05-31-2011, 03:59 PM
  3. Magnetic Ground Clamp
    By Meriasek in forum Welding
    Last Post: 05-11-2011, 11:13 AM
  4. Remote Fused Disconnect 'Melt Down'
    By Mrwurm in forum Rural Living
    Last Post: 06-09-2005, 08:05 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
