Page 1 of 3 123 LastLast
Results 1 to 10 of 29
  1. #1
    Join Date
    Jul 2011
    Posts
    105
    Billings, MT
    kubota L3400, Farmall 'A', Farmall F-14, Ford 860, JD 4520
    Default Pin to bushing clearance?
    I used 1" x 3/8" wall DOM tubing when I built the pin on style quick attach for the loader on my tractor. I had to take a die grinder with a burr bit to clearance the tubing to get a 1" pin to slide through it. Obviously this is not a precision way to do this although it did work. I have been looking for a hand reamer to do this and the closest one that I could find is a 1-1/16". This reamer would make the pin to bushing clearance 0.0156. My feeble mind tells me that this is too large and that the clearance should be closer to 0.006.
    Does anyone know what a good clearance fit between a pin and bushing should be? And more importantly, where in the Sam Hill do I find a hand reamer ? I'm toying around with the idea to build my own backhoe and it sure would be nice to have a faster and more precision way to ream a bunch of bushings. Thanks for your time.
    Steve
    Pin to bushing clearance?-done1-jpg.
  2. #2
    Join Date
    Nov 2012
    Posts
    147
    Canton, GA
    Kubota L3200
    Default
    I think if the holes line up correctly .010 would be a good clearance.
  3. #3
    Elite Member
    Join Date
    May 2012
    Posts
    2,972
    Knoxville, TN
    Bobcat CT225
    Default
    .10 should be plenty. Consider getting an adjustable reamer and then you can take it out little by little until it's exactly where you need it.
  4. #4
    Join Date
    Mar 2007
    Posts
    1,895
    Midwest
    Iseki TA 247. Husqvarna 54",Gravely Zero, Cub Zero,.Polaris 850 ATV's Stihl 018 026 Pro, 029, 034 Super AV, 039, 044 Mag. Stihl Pole Saw.
    Default Re: Pin to bushing clearance?
    I did nearly the same thing but I took the tube to the local machine shop and they bored it to accept 1" pins. Charged me $20.00. Another option besides a carbide burr would be a 1" cartridge roll at about 36 grit on a long mandrel. Or even a 1 1/4 flap wheel. Takes a little lomnger than a burr but you wont get the internal dings that a burr causes. Nice job by the way..
  5. #5
    Elite Member
    Join Date
    May 2012
    Posts
    2,972
    Knoxville, TN
    Bobcat CT225
    Default
    Likewise on the machine shop, but lots of people prefer to weld, then ream, since welding distorts the tube slightly,
  6. #6
    Join Date
    Jul 2003
    Posts
    1,845
    SW Indiana
    Ford 1920 4x4 (traded in on Kubota). Case 480F TLB w/4 in 1 bucket, 4x4. Gehl CTL60 tracked loader, Kubota L4330 GST
    I think 1/16 would wear and rattle.
    Misc. thoughts:
    Can you measure the pin precisely, ie mics or calipers?
    Try inserting a feeler gauge along one side of a factory hole/pin assembly to get an idea of proper clearance.
    Could your tubing be slightly oval?
    25mm bar would be .985". Might work with your existing tubing and be easier to find than a reamer.
    Some company must make off the shelf bushings like this for all the manufacturers.
    Lastly, find a hobby machinist or vocational school and have them tweak the bushing ID in a lathe. An expensive machine shop would be overkill for such a simple job.
  7. #7
    Join Date
    May 2007
    Posts
    704
    SW OH - near Dayton, OH
    1978 Kubota L285, 1951 Farmall h, 1946 Farmall m, 1950 John Deere A, 1953 Ford NAA Golden Jubilee, 195? Ford 850, 1948 Case DC
    My method for non-critical fitments:
    a) Carbide burr in die-grinder for roughing in. (Use the biggest diameter burr tool that I can for hole size as it helps keep it round when free-handing).
    b) Sand roll in die-grinder for finishing or minimum material removal. (again use biggest diameter roll that I can for the hole to help keep round).
    c) If you want to get super critical then you can use a cheapo brake cylinder hone in a drill for the final few thousands of finishing.
    Obviously critical tolerance fitments should be done in the machine shop realm which I do not have.
  8. #8
    Elite Member
    Join Date
    Jul 2006
    Posts
    4,409
    Northwest, WA
    Quote Originally Posted by rankrank1 View Post
    I'm lacking a reamer in my shop and this is what I ended up using. Slow but got the job done.
    ::Sent from a standard desktop keyboard::
    My Photobucket
  9. #9
    Silver Member dkhntr04's Avatar
    Join Date
    Sep 2010
    Posts
    169
    Northern MN
    Deere 3720 Cab
    Ask about "repair sleeve" at your local steel supplier. I do not know the specifics on the steel alloy or brand name, but it is a much harder/tougher steel than A36 but it machines and welds nicely. It comes in over/under sizes, so if you wanted a 1" ID and 1.5" OD the repair sleeve would be something around 1.010" ID and 1.490" OD give or take. I have not mic'd it. You can weld on the tube and for the most part a nominally sized pin will still fit even with distortion. I have used it to rebush an entire FEL on a row-crop tractor, and on a multitude of other projects.
    If it is an existing unit you are working on, I second the adjustable reamer.
  10. #10
    Join Date
    Oct 2010
    Posts
    767
    If you get a 1" reamer, 1" cold rolled or stress proof will fit as it's done to a more precise size usually nothing over and only a few tho under.....Mike
Similar Threads
  1. Quick Hitches Bushing rolled pin size?
    By Herkypilot in forum Attachments
    Last Post: 12-17-2011, 07:44 AM
  2. pin and bushing or swivel joint
    By dirt clod in forum Build-It Yourself
    Last Post: 11-25-2009, 11:48 PM
  3. I-Match bushing spiral roll pin
    By DrainPondDesign in forum John Deere Owning/Operating
    Last Post: 09-09-2008, 05:23 PM
  4. Pin and Bushing help needed
    By EddieWalker in forum Build-It Yourself
    Last Post: 09-11-2007, 01:02 PM
  5. Hinged Box Blade to pin or not to pin? How'd Udoit
    By stevenf in forum Attachments
    Last Post: 05-26-2006, 11:19 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
