Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 31
  1. #11
    Gold Member HarryN's Avatar
    Join Date
    Aug 2011
    Posts
    289
    Covington, Louisiana USA
    1999 Bobcat 763F John Deer 850 Grasshopper 723K H2
    Default Re: Anyone have (or access to) a small CNC plasma/water jet/laser cutter?
    Being that you're from Holden, you may know this place. Called "Water Cut" on hwy 59 in Abita Springs.
    Has done work for me and a good guy to boot. See Mr. Salter there. Good luck.
    Show us some pictures of your finished product if you can.....
  2. #12
    Platinum Member jwmorris's Avatar
    Join Date
    Oct 2007
    Posts
    700
    Simple stuff like that is why I built a pantograph. Sawing a template out of plastic takes less time than programming and setting up my CNC plasma. The $80 labor was because they don't like to set everything up just for one part. Order a few hundred and they would get real cheap.
  3. #13
    Join Date
    Jun 2011
    Posts
    599
    kubota L4400
    Default
    Kinda easy to make to be honest. What kind of tools do you have available. Even a circular saw with a abrassive wheel would make short work roughing out the pattern. Then tack two of them together at a time and finish up on two pieces instead of four. If you have, you can holesaw the radius in the v as well. For nice well rounded corners put your grinder in a vise upside down with a flap wheel on it. Comes out beautiful!
  4. #14
    Join Date
    Jan 2006
    Posts
    1,147
    Mass, Northshore, Merrimack Valley
    B6100DT
    Quote Originally Posted by Jarrett View Post
    Thanks for the input guys! I did provide the ACAD drawing to all the shops, so all they had to do was import it to their CAM software and finalize the programming. I'm just going to try to make the time to do it by hand.
    i've used these guys in the past:
    Rapid Sheet Metal - The Fastest Prototype SheetMetal Source
    Dan C.
    B6100DT, FEL, BH
  5. #15
    Super Member grsthegreat's Avatar
    Join Date
    Jan 2011
    Posts
    7,034
    north idaho
    Kioti DK45SE hst cab
    I have a cnc plasma table, but honestly $80 for a laser is VERY reasonable. The local dealer here spent over $1,000,000 installing their laser.
    Shipping metals from Idaho, labor to set up and cut, i probably couldnt do it any cheaper.
    currently own
    2011 Kioti DK45SE HST CAB tractor/loader, Jimna 6" - 3 point wood chipper, 60" JD Brush Hog, JD 60" Rototiller, 3 point post hole digger with hydraulic assist, 3 point spring tooth rake, Fimco 55 gallon weed sprayer with 12 foot boom, 3 point hydraulic wood splitter (home built)
    Quick Attach 79" loader mount snowblower & rear powerpack
    Quick Attach 84" Snow Blade
    Quick Attach 42" pallet forks
  6. #16
    Join Date
    Oct 2007
    Posts
    700
    This is the pantograph I was talking about in an above post. Should have made it 20 years earlier, very useful for many projects. And a lot of templates are quicker to make up for a few parts than making the program and loading it into the computer that runs the CNC.
    Attached Thumbnails Attached Thumbnails Anyone have (or access to) a small CNC plasma/water jet/laser cutter?-img_20130430_213321_355-jpg   Anyone have (or access to) a small CNC plasma/water jet/laser cutter?-img_20130430_213403_422-jpg
  7. #17
    Gold Member
    Join Date
    Jan 2010
    Posts
    334
    New Hampshire
    Kubota 4310 Kubota RTV900
    I have a home based metal shop with 2 cnc plasma machines. The parts you show would be around $12 each out of 3/16" steel......shipping via USPS flat rate (for 4 pieces) would be about $16. The parts would be within .020"....holes within .010".
    I would use my PlasmaCam machine...drawing the part using PlasmaCam software would take me roughly 5 minutes, cutting the part with a Powermax85 (Hypertherm) plasma would take about 35 seconds. The holes would be cut slightly under, then drilled with the proper sized drill. I can do the parts tomorrow.
    Here are some other similar parts done in my shop.Anyone have (or access to) a small CNC plasma/water jet/laser cutter?-250-cuts-001-jpgAnyone have (or access to) a small CNC plasma/water jet/laser cutter?-img_2766-jpgAnyone have (or access to) a small CNC plasma/water jet/laser cutter?-img_2421-jpg
    Jim Colt I work for Hypertherm.....but have a home based light fabricating business that my son operates. jim.colt@hypertherm.com
    Update....I had a few minutes so I drew the part in CAD as posted. The part cut from 3/16" steel will be $10.43 each. 4 of them will fit in a flat rate medium box ....which is $11.30 shipping in the 50 states. So, for $41.74 + $11.30 shipping....you can get your parts cut accurately and quickly with plasma. My son has no minimums....and will ship anywhere in the US and Canada
    I'm making a bracket to mount my 15 gal sprayer to my ZTR mower and I need some steel sheet cut out. I already have some material and can do it myself with the few tools that I have (portaband, grinder, etc.), but I don't really have the time to spend on cutting these out. I got prices from a few local shops here, but they were all way more than I'm care to spend. One shop quoted $3+ for material and $80 labor (laser). I'm not saying they're out of line. These are large shops with large machines, so their overhead just to start the machines up is high I'm sure. I don't know of any other shop locally that is a smaller operation with smaller machines and lower operating costs. Does anyone here do this line of work or know of any place online that provides these services? I've attached a picture of the bracket.
    Attachment 314687
  8. #18
    Join Date
    Oct 2007
    Posts
    700
    That deal is like a sore Peter...can't be beat.
  9. #19
    Join Date
    Aug 2004
    Posts
    1,914
    Caldwell Co. NC
    2006 Kama554; 92 Belarus 250AS
    Meat rhymes better with beat.
    Jim Colt those are great rates. I'll have to keep you in mind if I need anything like that in the future. How thick can you cut?
    2006 Kama 554, 92 Belarus 250AS, Bombardier Outlander Max 400.
  10. #20
    Gold Member
    Join Date
    Jan 2010
    Posts
    334
    New Hampshire
    We like to stay at 1/2" and under.....but we will do relatively small jobs up to 1". Just don't have good material handling capability just yet. With flat rate mailing from the postal service.....and parts with the largest dimension being 12".....you can ship up to 70 lbs for under $16 anywhere in the 50 states.
    Jim Colt
    Quote Originally Posted by Brad_Blazer View Post
Similar Threads
  1. GPS and laser leveling for small irrigated plots.
    By jenkinsph in forum Attachments
    Last Post: 01-31-2013, 12:36 AM
  2. Plasma or Laser Cutting Services
    By tkappeler in forum Build-It Yourself
    Last Post: 09-18-2012, 01:55 PM
  3. Plasma cutter
    By ENG18LT in forum Welding
    Last Post: 03-15-2012, 05:41 PM
  4. Clearing water access land questions...
    By acs55812 in forum Land Clearing Equipment
    Last Post: 09-06-2011, 11:14 AM
  5. Fun with Plasma cutter
    By AlanB in forum Projects
    Last Post: 02-15-2007, 01:08 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
