Page 1 of 4 1234 LastLast
Results 1 to 10 of 31
  1. #1
    Silver Member Jarrett's Avatar
    Join Date
    May 2004
    Posts
    231
    Holden, Louisiana
    Kubota L3130DT
    Default Anyone have (or access to) a small CNC plasma/water jet/laser cutter?
    I'm making a bracket to mount my 15 gal sprayer to my ZTR mower and I need some steel sheet cut out. I already have some material and can do it myself with the few tools that I have (portaband, grinder, etc.), but I don't really have the time to spend on cutting these out. I got prices from a few local shops here, but they were all way more than I'm care to spend. One shop quoted $3+ for material and $80 labor (laser). I'm not saying they're out of line. These are large shops with large machines, so their overhead just to start the machines up is high I'm sure. I don't know of any other shop locally that is a smaller operation with smaller machines and lower operating costs. Does anyone here do this line of work or know of any place online that provides these services? I've attached a picture of the bracket.
    Anyone have (or access to) a small CNC plasma/water jet/laser cutter?-mower-bracket_02-jpg
  2. #2
    Join Date
    Apr 2012
    Posts
    96
    Fife Lake Mi
    None
    Default Re: Anyone have (or access to) a small CNC plasma/water jet/laser cutter?
    Have you got any community colleges nearby? Some high schools may also have them.
  3. #3
    Join Date
    Sep 2012
    Posts
    1,208
    north shore MA.
    Default
    what are the tolerances?
    That can make a big differance on the price. If you can live with plus or minus 1/16" on most of your part it might lower the cost.
    At work we often get prints that are over toleranced, and the cost goes up.
    Dan H.
  4. #4
    Join Date
    Mar 2007
    Posts
    1,896
    Midwest
    Iseki TA 247. Husqvarna 54",Gravely Zero, Cub Zero,.Polaris 850 ATV's Stihl 018 026 Pro, 029, 034 Super AV, 039, 044 Mag. Stihl Pole Saw.
    Pretty Easy part. Find someone with a hand held Plasma and cut it out. Doesn't have to be perfect. Or if it does have to be perfect. Pay up.
  5. #5
    Join Date
    May 2004
    Posts
    231
    Holden, Louisiana
    Kubota L3130DT
    Plus or minus 1/16" is fine. I don't know anyone with a plasma. Hopefully someday I'll have one myself.
  6. #6
    Veteran Member CliffordK's Avatar
    Join Date
    Mar 2013
    Posts
    1,202
    Eugene, Oregon
    Toro D200, Ford 1715, International 884,
    It is relatively thin stuff.
    You have a nice drawing.
    I'd just cut it out with an angle grinder.
    A little filing, and you should be able to get a fairly nice piece. The most difficult thing is working around the little ears on the end, and getting a nice radius rather than a V in the middle.
    Ahhh, you need 4 of them? Well that is a bit of a pain, but still very possible.
    I could probably mill it pretty quickly on my mill too, although, at this point it would take more time to do the setup than the actual project. That may be what your machine shop is also saying. Someone still has to program their CNC. $80 for all 4 pieces doesn't sound too bad.
  7. #7
    Veteran Member flyerdan's Avatar
    Join Date
    Aug 2011
    Posts
    1,245
    Salem, OR
    Hyster H50 Bobcat M700
    Since there are only 4, I'd probably cut the blanks, rough out the V-section with a skinny wheel, then tack all 4 pieces together in a stack to do the drilling, radius, and finish work on the inside of the V. Grind the tacks off and deburr.
    Whoever said that you can't fight city hall had obviously never met Marvin Heemeyer.
  8. #8
    Join Date
    Nov 2008
    Posts
    1,191
    Covington, GA
    JD 870
    If that was an Autocad file then the one CNC plasma cutter I saw you just feed it the cad file. Well I sketched it, the cad jockey spent 5 minutes in Autocad, and then we walked out to the plasma cutter, pulled the cad file from the folder, a few minutes later it was done. Of course you have a rather expensive machine that the shop will charge you to use, plus if your drawing is not the correct format they have to fix that.
  9. #9
    Join Date
    Aug 2004
    Posts
    1,944
    Caldwell Co. NC
    2006 Kama554; 92 Belarus 250AS
    That quote seems in line. You could try a place like this: CNC Plasma Cutting
    I don't know anything about them other than their web site. Your parts would ship easily.
    If you spend 2 hours chasing a source, you could have them hand carved by then.
    2006 Kama 554, 92 Belarus 250AS, Bombardier Outlander Max 400.
  10. #10
    Join Date
    May 2004
    Posts
    231
    Holden, Louisiana
    Kubota L3130DT
    Thanks for the input guys! I did provide the ACAD drawing to all the shops, so all they had to do was import it to their CAM software and finalize the programming. I'm just going to try to make the time to do it by hand.
Similar Threads
  1. GPS and laser leveling for small irrigated plots.
    By jenkinsph in forum Attachments
    Last Post: 01-30-2013, 11:36 PM
  2. Plasma or Laser Cutting Services
    By tkappeler in forum Build-It Yourself
    Last Post: 09-18-2012, 12:55 PM
  3. Plasma cutter
    By ENG18LT in forum Welding
    Last Post: 03-15-2012, 04:41 PM
  4. Clearing water access land questions...
    By acs55812 in forum Land Clearing Equipment
    Last Post: 09-06-2011, 10:14 AM
  5. Fun with Plasma cutter
    By AlanB in forum Projects
    Last Post: 02-15-2007, 12:08 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
