Page 3 of 8 FirstFirst 123456 ... LastLast
Results 21 to 30 of 77
  1. #21
    Super Member Shield Arc's Avatar
    Join Date
    Jan 2009
    Posts
    6,063
    Port Orchard, WA.
    John Deere, 4200
    Default Re: LINCOLN 225
    Does that AC version have tapped settings? If so I can't imagine using a machine like that!
    Miller Dynasty 300.
    Lincoln V350-Pro w/pulse.
    Lincoln LF-74 wire feeder.
    Lincoln SG Spool gun.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    Everlast PowerArc 200ST.
    3 Lincoln SA-200s.
    Vantage 400
    1800 Ellis saw.
    Hypertherm Powermax 1250, CNC table.
    PROFAX Welding Positioner.
    JD2 model 3.
  2. #22
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,712
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    that's one thing I like about my hobart stickmate 235ac. I can run 100% duty cycle on t he 90-ish amp range that I normally use.
  3. #23
    Platinum Member pjbci's Avatar
    Join Date
    Feb 2012
    Posts
    712
    Summit. Ms
    JD 4840, 450j, 310, komatsu D31px22, IH 1486, MF 135, MHF TO35
    Default
    Im pretty sure the lincoln has 100% duty cycle on AC also. Mine has never shut me off on AC. But i used to do a lot of stick welding on aluminun dump trailers on DC and it would drive me nuts waiting for the machine to cool of and reset.
  4. #24
    Join Date
    Mar 2013
    Posts
    213
    Texas
    Hobart LX 235
    100% at 90
    20% at 225
    what about the Lincoln?
  5. #25
    Join Date
    Mar 2002
    Posts
    52,712
    Central florida
    Quote Originally Posted by DXN1EL View Post
    Hobart LX 235
    100% at 90
    20% at 225
    the lincoln uses a knob selector vs a continous control. but that's not a huge issue.
    i had heard they were using aluminum windings. but again.. for the $$ on an economy machine.. still not a bad value for the amps.
    if I had to buy another stick welder right now.. a lincoln or hobart would still be on my list of runners..
  6. #26
    Join Date
    Mar 2013
    Posts
    1,861
    Edmonton, Alberta
    MF 135
    Yes, they are aluminum wires in the Lincoln and it is a tapped current control and 20% duty cycle. Actually, according to Lincoln, they have a 20% duty cycle on ALL settings except the 75 amp setting. This setting used to have a circle around it and was used with a carbon arc torch or a pipe thawing unit, both of which are no longer available. Having a 50 year old Lincoln SA200 Red Face is a good thing to have. Having a Lincoln AC 225 or AC 225/DC 125 that is 50 year old technology... not so much. Nothing wrong if you already have one but to buy a brand new one when there are so much better and less expensive machines on the market doesn't make sense to me. I'm 99.9% certain Shield Arc only mentioned the AC/DC version because DC is much easier to weld with than AC. If you are dead set on having a Lincoln welder, look for a used Idealarc 250 AC/DC. Then you will have an excellent machine. Lincoln has a lot of components made in Mexico, Italy and I'm sure other countries as well. If you're a beginner welder, having the best machine you can afford will drastically reduce the learning curve and frustration level. This is only my opinion but if you limit your choices when looking at a welding machine, you're limiting your chances of getting good at it. Sorry if I seem harsh. That's not my intent. I don't want to see someone spend their hard earned money on something they'll want to replace after they try a better machine.
  7. #27
    Join Date
    Jan 2009
    Posts
    6,063
    Port Orchard, WA.
    John Deere, 4200
    Until joining these tractor forums I never thought about welding on AC except with Tig aluminum. In my line of work we ran into arc blow all the time, but we only used engine drives, so AC machines were all most unheard of. I took my Montgomery Wards buzz box and did some comparison welding with 7018. You can see in the AC plate where I lost the arc a couple times, and see all the splatter.
    When you have some time here are a couple article about welding on AC. In the last paragraph of the Lincoln article pretty much sums it up about welding with AC.
    "The first, most common situation is when you have no choice. This is because you are using a power source with AC output only. This is typical with low cost, entry-level type welding machines, often referred to as a buzz box welder".
    DC vs. AC Polarity for SMAW
    Miller - Basic Tips to Improve Stick Welding
    As the resident welding expert already said, "your money.. your call".
    Attached Thumbnails Attached Thumbnails LINCOLN 225-7018-acdc-jpg   LINCOLN 225-7018-ac2-jpg   LINCOLN 225-7018-dc2-jpg
    Miller Dynasty 300.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    3 Lincoln SA-200s.
    Vantage 400
    1800 Ellis saw.
    JD2 model 3.
  8. #28
    Join Date
    Mar 2013
    Posts
    213
    Texas
    Yes.. I know it is 50 year old welder, but my pocket is sort. What other stick welder can be good for me as my first welder?
    or maybe should I wait a little a get something better like
    FREE SHIPPING Hobart Stickmate Stickmate LX 300 AC/200 DC 230V Arc Welder/Stick Welder 205 Amp Output, Model# 500560 | Arc Welders| Northern Tool + Equipment
    what do you guys think?
  9. #29
    Join Date
    Jun 2011
    Posts
    599
    kubota L4400
    Default
    If money is short either wait or buy used. The guys keep talking to you nicely but you are not listening. That machine is a piece of sh!t, but it will get you through jobs. So in short if money is tight, dont spend it twice. Jmho!
  10. #30
    Elite Member
    Join Date
    May 2012
    Posts
    2,972
    Knoxville, TN
    Bobcat CT225
    Default
    I'm not sure why somebody is holding up "heavy" as a plus. My PA160 weighs 35 lbs. I don't miss lugging my old transformer welder around one bit.
Similar Threads
  1. Lincoln Ranger 225 VS, Lincoln Eagle 10000
    By loudhornsrule in forum Welding
    Last Post: 02-06-2013, 01:23 PM
  2. Lincoln MIG-Pak 180
    By dmay in forum Welding
    Last Post: 03-31-2011, 01:11 PM
  3. Hello From Lincoln Co. NC
    By doonapo21 in forum New Member Introductions
    Last Post: 10-15-2009, 06:59 PM
  4. Lincoln 175 or 175 Plus
    By BobReeves in forum Build-It Yourself
    Last Post: 06-17-2006, 10:37 AM
  5. VW vs Lincoln
    By BobinCols in forum Related Topics
    Last Post: 12-15-2002, 07:17 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
