Page 1 of 6 1234 ... LastLast
Results 1 to 10 of 55
  1. #1
    Elite Member
    Join Date
    May 2012
    Posts
    2,972
    Knoxville, TN
    Bobcat CT225
    Default Bending tube with a TIG torch
    I welded some 1" x 1/8" thick tube into a T today. The "top" of the T warped slightly, of course. I know one way to bend it back is to weld a bead on the back side of the joint; I believe the bead should be perpendicular to the length of the tube, is that right?
    I was also wondering if I could bend it back just by heating the back side with my TIG torch, but not to such a heat that the metal actually melted. Some web searching indicates that I'm not the first to suggest this, but I'd love to hear if others think it would work. That would save me having to grind off the weld after the fact--and, of course, give me more opportunity to use my awesome TIG setup!
  2. #2
    Join Date
    Sep 2012
    Posts
    1,208
    north shore MA.
    Default
    grab a strait piece of left over tube and try it first. You will need to figure out how big of a spot to heat.
    And don't forget to let it cool off. The bending happens uppon cooling. Several attempts will heat the whole part so that your target spot won't cool quickly.
    Dan H.
  3. #3
    Elite Member
    Join Date
    May 2012
    Posts
    2,972
    Knoxville, TN
    Bobcat CT225
    Default Re: Bending tube with a TIG torch
    Well, here's what I found.
    The TIG torch, as you would expect, was more than capable of heating a 1" square section of the tube to red hot. I used about 80 amps at first, then stepped up to 100 when that didn't do it. Bottom line: simply heating the tube to red hot is insufficient to cause it warp all on its own. Next, I intentionally built up a melted spot about 1" in diameter and let it cool. No dice. Finally, I put a huge blob of 7018 onto it--probably about 1/4 to 1/3 of a rod, and I intentionally washed down onto the side a little bit in case that mattered. No dice. The piece of scrap is still perfectly straight.
    So... I dunno. Apparently, if I put down 4" of weld around a piece of tubing, that warps the piece, but if I blob down 7018 like there's no tomorrow, it laughs it off.
    I think that I may end up having to clamp the piece and then heat it, which will be terribly awkward, but I guess I'll have to find a way.
  4. #4
    Super Star Member
    Join Date
    Jul 2011
    Posts
    14,436
    Yanceyville, North Carolina
    Kubota L4400
    Just a thought? Could you utilize a Pipe Bender like Electricians use? I mean for the initial bend. Perhaps, also for reversing the process? I'm only attempting to help. Best wishes.
    The PUPIL who does not surpass his Master, fails his Master.
  5. #5
    Elite Member
    Join Date
    May 2012
    Posts
    2,972
    Knoxville, TN
    Bobcat CT225
    Quote Originally Posted by creekbend View Post
    I don't know whether that would work. I'm just trying to correct warpage here, not actually create a bend. I'm also not sure that pipe benders can handle square tube.
  6. #6
    Elite Member
    Join Date
    May 2012
    Posts
    2,972
    Knoxville, TN
    Bobcat CT225
    Here's a photo of the piece, if you're curious.
    Bending tube with a TIG torch-2013-06-07-00-49-a
  7. #7
    Elite Member
    Join Date
    May 2012
    Posts
    2,972
    Knoxville, TN
    Bobcat CT225
    Default
    What if I was to clamp the piece at the ends, with a fulcrum under the joint, then bend it back to straight and remelt the joints with the torch? Leave it clamped until it cooled.
    It was heating the top side of the tube that warped it. Heating the bottom side is one way to bend it back, but it seems like if the metal was hot on top, it would loosen up again and be susceptible to clamping. Or would putting more heat into the joint just make things worse once I removed the clamps?
  8. #8
    Super Member Shield Arc's Avatar
    Join Date
    Jan 2009
    Posts
    6,011
    Port Orchard, WA.
    John Deere, 4200
    I would think heat is heat. Never used a Tig torch before. Always used O&A torch. Since switching to propane I've leaned I don't like propane for heat shrinking material as much as acetylene. Here are some different examples of how I would heat shrink a T-joint. If you can heat these areas red hot, and use a spray bottle of water to cool the heated zone. The material must be cool to the touch before re-heating. Remember if you can feel heat with your hand, the material is still moving!
    Attached Thumbnails Attached Thumbnails Bending tube with a TIG torch-weld-2-1st-jpg   Bending tube with a TIG torch-weld-2-2nd-jpg   Bending tube with a TIG torch-weld-2-jpg
    Miller Dynasty 300.
    Lincoln V350-Pro w/pulse.
    Lincoln LF-74 wire feeder.
    Lincoln SG Spool gun.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    Everlast PowerArc 200ST.
    3 Lincoln SA-200s.
    Vantage 400
    1800 Ellis saw.
    Hypertherm Powermax 1250, CNC table.
    PROFAX Welding Positioner.
    JD2 model 3.
  9. #9
    Join Date
    Sep 2012
    Posts
    1,208
    north shore MA.
    Default
    Josh: you need to heat a small area quickly without heating the surounding area. That will make the heated area have no where to go but up. Then as it cools it will pull in the surounding area. Lots of heat, short time.
    Dan H.
  10. #10
    Elite Member
    Join Date
    May 2012
    Posts
    2,972
    Knoxville, TN
    Bobcat CT225
    Quote Originally Posted by CNC Dan View Post
    So, what I was doing was using maybe 80-100 amps and washing over a large area to make it red, but now I think that may be more of an approach that would be used for making the metal malleable for bending, but not for inducing anti-warpage like I want to do. Based on what you're saying, I'm thinking, if I was going to use a TIG torch, I would want to set it to max output (160 amps in my case) and use the finger-switch to hit the metal with quick bursts of heat--perhaps moving over the corners behind the joint, like in Shield Arc's example.
Similar Threads
  1. TIG gas lens parts question
    By joshuabardwell in forum Welding
    Last Post: 06-01-2013, 03:15 PM
  2. Redneck Stick Electrode Holder from TIG Wire
    By ChuckE2009 in forum Welding
    Last Post: 05-09-2013, 12:56 PM
  3. My new bending toy
    By daedong in forum Related Topics
    Last Post: 06-30-2012, 10:04 PM
  4. To TUBE or not to TUBE: that is the qestion?
    By LD1 in forum Owning/Operating
    Last Post: 05-17-2012, 11:01 AM
  5. Leaky stem on loaded tire.. to tube or not to tube?
    By CORamos in forum Kubota Owning/Operating
    Last Post: 08-03-2011, 10:47 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
