Results 1 to 3 of 3
  1. #1
    Veteran Member deereman75's Avatar
    Join Date
    Apr 2011
    Posts
    1,754
    canada
    1946 cockshutt 60
    Default Big Migs to look for
    Well, if any of my job applications pan out, I hope to be adding a mig to the fleet before long. I am looking on suggestions of used full sized Migs (250 class) to look out for. So far, my watch list consists of the L-tec/esab migmaster 250, and the hobart beta mig 250 (Just saw one for $450.. If I had the cash it would be in my shop now.. ) Miller and Lincoln would only be on the list if I found a real killer deal. Any other lesser known, but good Migs to keep my eye out for?
    Never carry gasoline in your car trunk. If you do, atleast use some sort of container.
    -red green
  2. #2
    Super Member Shield Arc's Avatar
    Join Date
    Jan 2009
    Posts
    6,064
    Port Orchard, WA.
    John Deere, 4200
    Default Re: Big Migs to look for
    I've never been around a Hobart Mig machine, and haven't heard a whole lot about them. Heard nothing but good things about ESAB Mig machines.
    No matter what you buy, try to get one with variable inductance! I had a Linde VI-206 for almost 10-years, it had variable inductance. Really nice option to have!
    Attached Thumbnails Attached Thumbnails Big Migs to look for-mig-station-jpg
    Miller Dynasty 300.
    Lincoln V350-Pro w/pulse.
    Lincoln LF-74 wire feeder.
    Lincoln SG Spool gun.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    Everlast PowerArc 200ST.
    3 Lincoln SA-200s.
    Vantage 400
    1800 Ellis saw.
    Hypertherm Powermax 1250, CNC table.
    PROFAX Welding Positioner.
    JD2 model 3.
  3. #3
    Elite Member
    Join Date
    Jul 2006
    Posts
    4,264
    South Central OK
    Kubota Grand L-4610HSTC
    I have a Hobart Handler 210 (does 210 amps) and I like it very much. It came with an accessory spool gun which is handy for stainless and aluminum. I usually use it with Argon/CO2 for steel but use 100% argon with aluminum. It also does fine with flux cored wire. It has a handle on top and is listed as portable but it does weigh 85 lbs. I have it mounted on my welding trailer with home brew winged bolts (hex head bolts with washers welded on.) When it won't reach the work ( I take the trailer out off road to get to gates, pens etc on my cattle ranch) I can pull the two bolts and carry the unit closer to the work. The really big floor model welders aren't all that easy to take off road and then hand cary.
    FWIW I don't have an engine driven welder. I have a 17,500 watt Generac electric start gasoline powered generator which powers my little welding trailer and its complement of equipment: 14 inch chop saw, dual 8 inch pedestal mounted grinder, vise, Lincoln tombstone AC-DC stick welder, HyperTherm Plasma Cutter, 240 volt air compressor, and an assortment of 4 1/2 and 7 inch hand held grinders etc, Oodles of convenience outlets for 120 VAC and 240 VAC. When there is 240 VAC available within 100 ft of the trailer with a compatible outlet (or matches one of my adaptors) I can plug the trailer into commercial power and run everything without running the generator. For example, when the trailer is parked inside my metal working shop.
    I might mention that the 240 volt 50 amp 100 ft extension cord (in two pieces, a short one 30+ feet and a long one 60+ feet) made by cutting up a used 100 ft cord) is a heavy sucker to carry very far.
    And to add a belt to the suspenders, the generator can power the house in the event that the propane fired automatic standby genset is inop or the two 1000 gal propane tanks are empty.
    Pat
    Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun.
Similar Threads
  1. Little Trees with Big Hopes
    By lakngulf in forum Food Plots
    Last Post: 07-04-2013, 02:26 PM
  2. JD D170- Help! Big Mistake!?!?
    By jebm in forum Parts/Repairs
    Last Post: 06-11-2013, 12:35 PM
  3. It's big, it's blue.. it's a 252!
    By Scooby074 in forum Welding
    Last Post: 05-23-2013, 12:22 AM
  4. How BIG a splitter do I need for this project?
    By Arkaybee in forum Projects
    Last Post: 05-12-2013, 12:25 PM
  5. Small MIGs Really any difference?
    By g42guy in forum Build-It Yourself
    Last Post: 11-14-2004, 08:12 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
