Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1
    Veteran Member deereman75's Avatar
    Join Date
    Apr 2011
    Posts
    1,622
    canada
    Default $4 torch score!
    I think I did pretty good on this straight torch. Only cost me $4 (yes really!) It's a really old Harris model 76. Some bits look a little rough, but everything seemed to check out alright. The valves all work properly, and nothing seems to leak. Any thing else I should check before lighting it up? I don't trust the tip, it got a bit mangled during removal (I didn't realize it was a screw off, and ended up separating the two pieces) The torch its self was unharmed (close inspection revealed absolutely no damage) But since I don't want to take any chances, I am ordering a tip adapter, and a cutting tip. I am also getting a tip adapter for my airco, and the rosebud for the adapter. Everything seems mechanically perfect, and I can't find anything wrong. But if any of you torch experts have something else I should check, PLEASE tell me!
    Now for some pictures.
     torch score!-img_00000055.jpg torch score!-img_00000056.jpg torch score!-img_00000057.jpg torch score!-img_00000058.jpg
    "If the women don't find you handsome, they should at least find you handy" - Red Green
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
  3. #2
    Join Date
    Mar 2007
    Posts
    1,032
    Midwest
    Iseki TA 247. Husqvarna 54", Cub Zero Turn.Polaris 850 ATV's Stihl 018 026 Pro, 029, 034 Super AV, 039, 044 Mag. Stihl Pole Saw.
    Default Re: $4 torch score!
    Everything seats and seems to be good right. The tip does not look like a Harris 6290. I think you will have a hard time getting a tip for it unless GOSS has one. If it is a 6290-whatever. let me know. Good Luck..
  4. #3
    Join Date
    Apr 2011
    Posts
    1,622
    canada
    Everything seems perfectly fine. It's a 7490 tip (I checked a chart) There is an American torch tip adapter for that one, so that is the route I will go. I figured at $4 even if it ended up being a wall hanger, it was still worth it.
  5. #4
    Join Date
    Mar 2007
    Posts
    1,032
    Midwest
    I love the old torches. The Brass is worth 4 bucks.
  6. #5
    Join Date
    Apr 2011
    Posts
    1,622
    canada
    I think the torch may have got some oil in it..
    I have some chlorinated brake cleaner (PERC) would that work? It leaves no residue. I also have a can of trichlorethylene, would that be better? If you think neither is OK, where can I get the proper regulator cleaner?
  7. #6
    Join Date
    May 2008
    Posts
    856
    Eastern Ia
    JD 4310 eHydro, JD 322
    When I worked at a welding supply, we always used trich. That is what I would vote.
  8. #7
    Join Date
    Apr 2011
    Posts
    1,622
    canada
    OK, tonight I will tear the torch down, get it real clean with trich and put it back together. I'm ordering tips tonight.
  9. #8
    Join Date
    Mar 2007
    Posts
    1,032
    Midwest
    Trichlorethane or how ever you sp
    ell it is the best degreaser out there because it's non flamable. Definatly use it. It has been banned in USA due to someones thinking that it harmed the ozone. i still have 2 5 gln cans. it was also sold under the name Safety Solvent by a company named Crown. Very good stuff. Gun Scrubber spray would be a good 2nd choice.
  10. #9
    Elite Member
    Join Date
    Feb 2011
    Posts
    3,588
    Tucson AZ
    New Holland TC-45
    Years ago I had a Smith that would back fire & start burning in the handle. Still worked fine until it got so hot you could not hold it. In those days I had asbestos gloves and they only worked for a while.
    ::"I STARTED out with nothing....I still have most of it."
    New Holland TC45 1,300+ hours - FEL - back hoe - post hole digger - Hydraulic Gannon - cement mixer - pressure washer - 1975 Dodge 500 flat bed - 1974 chevy C65 6 yard dump truck.
    All home made by me. loading forks - 2 drags - roller - Sheep's Foot - Pusher (to unload flat bed truck.) - pickle fork digger - Log splitter -
  11. #10
    Platinum Member CliffordK's Avatar
    Join Date
    Mar 2013
    Posts
    649
    Eugene, Oregon
    Toro D200, Ford 1715, International 884,
    The new torches have flashback arrestors. The old ones don't.
    However, it hasn't ever seemed to be an issue for me.\
    I suppose, like a seat belt, you don't need it, until you really NEED it.
Similar Threads
  1. CL Score
    By foggy1111 in forum Attachments
    Last Post: 07-18-2012, 10:56 PM
  2. SCORE!!! at TSC
    By khamill2000 in forum Attachments
    Last Post: 10-05-2008, 08:34 AM
  3. What a score!! I think.
    By blagg in forum Attachments
    Last Post: 03-26-2008, 11:20 PM
  4. Score!
    By woodlandfarms in forum Power Trac
    Last Post: 08-24-2007, 09:21 PM
  5. How Does Your Dog Score?
    By DrDan in forum Related Topics
    Last Post: 06-16-2001, 05:24 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
