Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 47
  1. #11
    Super Member crazyal's Avatar
    Join Date
    Dec 2003
    Posts
    7,042
    Northern Vermont
    Kubota, Case, Deere
    Default Re: What can i weld with a Licoln Electric 115v welder?
    I had the same welder and yes you can weld 3/16" steel. A neighbor and I bought our Lincoln from Costco about 20 years ago. It had the infinite wire speed at 4 power settings. The flux core wire doesn't like to make multiple passes without removing the slag between each pass. I bought it for doing sheet metal work but found it to be more than capable for most welding. The biggest project I did with the welder was make a trailer out of 1/8" and 3/16" think steel. Still have the trailer today. It's been modified several times over the years but none of the original welds failed.
    Kubota L4240,Case 580K backhoe, Case 450 Dozer, Deere X500
  2. #12
    Super Member Shield Arc's Avatar
    Join Date
    Jan 2009
    Posts
    6,088
    Port Orchard, WA.
    John Deere, 4200
    Quote Originally Posted by stuckmotor View Post
    Can you not run multiple passes with a wire feed welder as is done with a stick welder? If not, why?
    In the 1970's for 3-years I worked in a NRC controlled shop. Every 3-months we had to stop production and head to the test booth. We had to re-qualify in every process we had certs in. All AWS unlimited V-butt plates and pipe tests for those of us who had pipe certs. The strange part is with each plate and position we had to run .030, .035, .045 and 1/16-inch wire, so we were qualified in each wire size too. Guess how many passes it will take to fill one of these plates up?
    Attached Thumbnails Attached Thumbnails What can i weld with a Licoln Electric 115v welder?-aws-1-inch-test-jpg
    Miller Dynasty 300.
    Lincoln V350-Pro w/pulse.
    Lincoln LF-74 wire feeder.
    Lincoln SG Spool gun.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    Everlast PowerArc 200ST.
    3 Lincoln SA-200s.
    Vantage 400
    1800 Ellis saw.
    Hypertherm Powermax 1250, CNC table.
    PROFAX Welding Positioner.
    JD2 model 3.
  3. #13
    Elite Member Piston's Avatar
    Join Date
    Sep 2008
    Posts
    3,717
    Lakes Region NH
    Kubota L4610 Hitachi UH083LC
    I'll have to check what kind of wire I have. I have a few rolls of it stashed in a cabinet, but I'm not sure what thickness it is, or if it is "flux" core that you talk about.
  4. #14
    Epic Contributor k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    28,351
    Branson, Mo.
    Kioti DK35se Hydrostat
    Let me take a stab at the "why can't I just make multiple pass question". and then we will let the pro's correct me if I am wrong. The simple answer is you can.. but if the first past and subsequent passes don't really "burn in" or penetrate properly because the parent metal is too thick and sucks what little heat you can deliver out of the weldment then you can pile up weld until the cows come home but it wont be as strong as if you were using a 220v machine that can have the heat turned up and properly penetrate with each and every pass needed to fill the gap of the weldment. I don't have a MIG, and have done very little MIG welding, but I think this could be a problem with welder that might not be able to get thick metal hot enough to begin with and not be able to handle the larger sizes of wire to deliver the current, and the primary voltage(115) just cannot ever deliver enough. Lets see what the guys that weld for a living say.
    James K0UA
    James K0UA
    Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. EA 50 inch single lid "wicked" Grapple. Satisfied Everlast PA160 welder owner NRA Life Member How to add a link to a post . Best way to search TBN . Igitur qui desiderat pacem praeparet bellum
  5. #15
    Join Date
    Jan 2009
    Posts
    6,088
    Port Orchard, WA.
    John Deere, 4200
    Quote Originally Posted by k0ua View Post
    James K0UA
    BINGO!
    Personally on the whole I think 120-volt Mig machines should be outlawed! Mig machines are just to darn easy to pickup and run a good looking bead. But that means nothing!
    If your Mig welds don't look something like this, back to the drawing board.
    Attached Thumbnails Attached Thumbnails What can i weld with a Licoln Electric 115v welder?-29-0-jpg
    Miller Dynasty 300.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    3 Lincoln SA-200s.
    Vantage 400
    1800 Ellis saw.
    JD2 model 3.
  6. #16
    Join Date
    Sep 2008
    Posts
    3,717
    Lakes Region NH
    Quote Originally Posted by Shield Arc View Post
    BINGO!
    Uuuummm, weeellll, they don't exactly look like that....
  7. #17
    Veteran Member ericher69's Avatar
    Join Date
    Aug 2008
    Posts
    1,670
    Ontario Canada
    2008 Kubota b2920
    Default
    BINGO!
    SA;
    That was done in spray transfer mode? With a 250+ amp machine...
    I know that every weld in a perfect world given unlimited money,resources, skill should be X-Ray quality but I personally don't believe that it needs to be so!
    Having said that you have been rubbing off on me with your saying (paraphrased)"most mig welds look good but are too cold"
    I have been turning up the heat more as of late.
    ericher69
    IAFF Local 849
  8. #18
    Elite Member
    Join Date
    Sep 2009
    Posts
    2,694
    Up State S.C.
    AC WD 34 hp/3500 lbs MF 261 60 hp/5380 lbs
    BINGO!
    Thanks for the enlightenment. I'm learning a lot from you gentlemen.
    Stuck
  9. #19
    Join Date
    Sep 2008
    Posts
    3,717
    Lakes Region NH
    Default
    Just out of curiosity, what welder would you guys suggest for a job like this? I'd like something that could weld up to 3/4" thickness. I'd like to spend less than 1k dollars.
    There are probably a bunch out there, but are there some good well known "all around" welder s that seem to be more popular than others?
  10. #20
    Join Date
    Oct 2010
    Posts
    769
    I'd like something that could weld up to 3/4" thickness.I'd like to spend less than 1k dollars.
    That's going to be a good size machine, If you're looking at mig, you're going to be hard pressed to get one under $1K. My own machine at home is a TA 181i that was CAN$949. If I had to do something out of 3/4 plate I'd use stick as the machine just isn't heavy enough for 3/4 even tho it's rated at 180A.
    For 3/4 plate you'd be looking at, in the TA Fabricator series, a 252i rated at 250A, a Miller 252 would be another and there's a lot more as well but under $1K....dunno.
    Could you do it with the 181, sure but it'd be along the same lines as the 110V mig, it'd work but it's not designed for that.
    Amen, you get people building trailers and the like to be hauled on the road and the welds are just stuck on there....Mike
Similar Threads
  1. Replies: 2
    Last Post: 03-19-2013, 09:36 PM
  2. MiG welder: how thick can it weld?
    By sevilla in forum Build-It Yourself
    Last Post: 03-08-2011, 10:33 PM
  3. hardly ever weld welder
    By arrow in forum Rural Living
    Last Post: 01-16-2010, 05:29 PM
  4. Lincoln Electric AC/DC 225/125 Welder
    By dirt clod in forum Parts/Repairs
    Last Post: 03-20-2008, 07:16 AM
  5. What kind of Rods to weld with a 110 welder
    By DaMadman in forum Build-It Yourself
    Last Post: 11-03-2005, 09:39 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
