Results 1 to 4 of 4
  1. #1
    Member
    Join Date
    Jul 2012
    Posts
    48
    Harford, Maryland
    Ford 550 TLB
    Default How would you set up S-32p with Bobcat 225?
    I am looking for some input. I just purchased a used Bobcat 225NT on a trailer. Included was a Miller S32P Super and a Bernard 300 amp mig gun. The S32P is missing some stuff and set up for 5/64 wire. There is no gas valve with it. I plan on using everything outside, mostly repairs to equipment, fences, railings, light fab work. I am looking to have a total mobile setup without a lot of overlap with what each machine will do.
    So my question is what would you set up the S32P with? Wire size? Add gas to it?
    Does anyone own this setup or any common problems?
    Thanks
  2. #2
    Join Date
    Mar 2013
    Posts
    1,844
    Edmonton, Alberta
    MF 135
    Default Re: How would you set up S-32p with Bobcat 225?
    A good general purpose self shielded flux-core wire would be the best bet and I'd recommend something like Hobart Fabshield 21B. Look it up on the internet and see what volts and amps is uses. 5/64" might be OK but I think .045 or 1/16" would be better. You can get stronger wires with impact strength if you need something really strong. Either that or just use 7018 stick rods. Getting a gas valve so you could run MIG would be a good idea but you'd have to be indoors or use a screen to block any wind. You never know when you might have sheet metal or a big gap to fill.
  3. #3
    Member
    Join Date
    Jul 2012
    Posts
    48
    Harford, Maryland
    Ford 550 TLB
    Thanks, I forgot to mention I do have a MIG setup with gas and .030 or .024 for use inside the shop. I thought the 5/64 might be a little large.
  4. #4
    Super Member Shield Arc's Avatar
    Join Date
    Jan 2009
    Posts
    5,994
    Port Orchard, WA.
    John Deere, 4200
    I couldn't even begin to tell you how many tons of 21-B I have run in the past. I would think with that small of welder 1/16-inch is as big as I would go. A lot of general fab work can be done with .045 wire.
    Product Details - Hobart Brothers Performance Welding Products
    Attached Thumbnails Attached Thumbnails How would you set up S-32p with Bobcat 225?-21b-jpg
    Miller Dynasty 300.
    Lincoln V350-Pro w/pulse.
    Lincoln LF-74 wire feeder.
    Lincoln SG Spool gun.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    Everlast PowerArc 200ST.
    3 Lincoln SA-200s.
    Vantage 400
    1800 Ellis saw.
    Hypertherm Powermax 1250, CNC table.
    PROFAX Welding Positioner.
    JD2 model 3.
Similar Threads
  1. 3 point hitch set up?
    By superbrat in forum Attachments
    Last Post: 06-09-2013, 05:24 PM
  2. gt 225 not starting.
    By keithmn in forum Parts/Repairs
    Last Post: 05-31-2013, 08:39 PM
  3. LINCOLN 225
    By DXN1EL in forum Welding
    Last Post: 05-19-2013, 08:16 AM
  4. open sockets i need a set
    By sam5570 in forum Projects
    Last Post: 05-07-2013, 09:15 PM
  5. California Need a set of fecon teeth
    By daveyclimber in forum Wanted Ads
    Last Post: 04-24-2013, 12:47 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
