Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    Super Member Iplayfarmer's Avatar
    Join Date
    Jul 2005
    Posts
    5,238
    Idaho
    Massey Ferguson 1215, Toro 266-H, Farmall Cub, Farmall A
    Default Old School Engine Driven Welder Loses RPM When I Strike an Arc.
    I picked up an old school engine driven welder today at a yard sale. I replaced the spark plug and cleaned the carb, and it runs great with one exception. When I strike an arc, the engine loses RPM and the rod sticks. I can get a bead with it, but it's really difficult.
    Is there some trick I don't know to keep the RPM up? It's a Ward welder with a Kohler engine. It's old school to the point that I have to wrap the cord around the flywheel before I start it.
    From now on I will only buy cars that are a silver/grey color. Then I can make all body repairs with Duct Tape.
  2. #2
    Gold Member DaveOmak's Avatar
    Join Date
    Sep 2009
    Posts
    465
    Omak, Washington
    '53 Jubilee
    Default Re: Old School Engine Driven Welder Loses RPM When I Strike an Arc.
    Sounds as if the governor is out of adjustment.... and/or the high speed fuel jet needs adjustment also, it could be a little lean...
    Dave
  3. #3
    Join Date
    Feb 2012
    Posts
    1,746
    Albany OR
    Case 580B, Long 460, Allis-Chalmers 160
    I started arc welding on an old Lincoln SA200 (friend's) that was crank start, don't remember much else about it - other than, it would idle til you struck an arc, then the governor would kick in - problem was, if you just tried to start welding, it would kill the motor - you had to "fake" an arc (scratch the rod against the piece), wait for the governor to rev up the engine, and THEN actually strike off and burn you're rod.
    Don't know from your comments yet if you're already doing that and STILL having problems, or??!?
    Or, Dave's on the money, you're doing everything right already, and yer in fer ANOTHER "ride" like the compressor
    Hopefully it'll be something easy this time... Steve
  4. #4
    Super Member Shield Arc's Avatar
    Join Date
    Jan 2009
    Posts
    6,083
    Port Orchard, WA.
    John Deere, 4200
    Quote Originally Posted by BukitCase View Post
    Generally when that happens the first thing to check is the idle RPMs. If the RPMs are to low the engine can't jump up to high RPMs when the arc is struck. If that isn't the case, then the idler has problems.
    Miller Dynasty 300.
    Lincoln V350-Pro w/pulse.
    Lincoln LF-74 wire feeder.
    Lincoln SG Spool gun.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    Everlast PowerArc 200ST.
    3 Lincoln SA-200s.
    Vantage 400
    1800 Ellis saw.
    Hypertherm Powermax 1250, CNC table.
    PROFAX Welding Positioner.
    JD2 model 3.
  5. #5
    Join Date
    Mar 2010
    Posts
    2,128
    Lincoln ranger 9 has a switch you flip which allows engine to idle between work loads and the other way it maintains a higher rev. I know yours is before this feature was invented. Turn the idle screw up alittle and see if this helps. If not the governor needs some attention. How long has it been sitting? The new gas has eatten up alot of small engine parts. The kohler is worth putting some money into.
  6. #6
    Join Date
    Jul 2005
    Posts
    5,238
    Idaho
    I think I figured it out. It was 2458n's comment that got me thinking. There's a little black knob in front of the air cleaner that I didn't know what it was (pictured). I connected it where it goes and tried the welder with it pulled out and locked in place.
    I didn't try to run a bead, but I did stick a rod for a few seconds just to see what happened. Voila!! the engine didn't loose much RPM. I'll try to run a bead tomorrow when I have a little more time and report back.
    Next question... What's the little electrical knob looking think that is just under the knob in the picture. It doesn't have any kind of button or anything, and there's a single wire coming in to the back of it.
    Attached Thumbnails Attached Thumbnails Old School Engine Driven Welder Loses RPM When I Strike an Arc.-img_0573-jpg
  7. #7
    Join Date
    Dec 2011
    Posts
    940
    Western Washington USA
    MM UTS and Homemade
    Looks like a kill switch, but I'm just guessing.
  8. #8
    Join Date
    Sep 2012
    Posts
    1,208
    north shore MA.
    Default
    Quote Originally Posted by Iplayfarmer
    Grounding lug?
    Dan H.
  9. #9
    Advertiser Mark @ Everlast's Avatar
    Join Date
    May 2010
    Posts
    2,271
    South GA
    Let's see the other sides of this thing! Nice find. The wire could be a converted hi/lo idler, or it could be as it was mentioned by bigdeano, a kill switch.
    Mark Lugo
    Everlast Welders
    http://www.everlastgenerators.com/
    Need a welder? Give me a call at (877) 755-9353 ext 204!
  10. #10
    Gold Member
    Join Date
    Jan 2006
    Posts
    441
    Stone Mountain, GA
    Case 1210, Mitsubishi D2050
    Sure looks like a kill switch. I only see one wire, which is probably for grounding the ignition primary. Does the wire go over towards the points or coil? If so that's what it is.
Similar Threads
  1. Engine RPM problem on my BX24
    By rnbrn21 in forum Kubota Owning/Operating
    Last Post: 04-27-2018, 02:08 PM
  2. Replies: 1
    Last Post: 08-07-2013, 10:54 AM
  3. Craftsman 50 amp home-n-shop arc welder
    By kennesm in forum Welding
    Last Post: 07-21-2013, 09:17 AM
  4. Oil & Fuel BX24: Engine RPM goes up and down sporadically
    By lilmatt in forum Kubota Owning/Operating
    Last Post: 05-26-2013, 03:37 PM
  5. School me on my new stick welder
    By Johnbro in forum Welding
    Last Post: 03-07-2012, 08:18 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
