Making a small chain
   / Making a small chain #1
k0ua
Epic Contributor
Branson, Mo.
Kioti DK35se Hydrostat
I will need a small piece of chain for a future project, and I did not feel like going to town to buy some, so I just made some.
First I took some hanger wire, originally intended to hang ceiling tile grid, and sanded off the coating. IMG_20131018_100930_781.jpg
Then I wound the wire around a piece of ground rod and cut it with a Dremel disk. As shown hereIMG_20131018_103554_525.jpg
Here is what the rings look like when they come off of the ground rod.IMG_20131018_104229_173.jpg
I formed the links using a pair of Linemans pliers as shown here. Keep the ends lined up for the welding operation to follow.IMG_20131018_105129_520.jpg
Here is the completed chain now ready to TIG weld the ends of each flattened link together. Gas welding would work as well or better. and I imagine MIG would work well here also. Stick welding would really suck at this operation.IMG_20131018_114918_529.jpg
And here is the completed chain. Some links look better than others, but they all held when I tried to pull it apart, and it will not have much stress on it for what I intend to use it for as a pin keeper chain.IMG_20131018_115507_563.jpg
Thanks for Looking.
James K0UA
   / Making a small chain #4
wow,nice work ! good thing I didn't ask you what time it was, I'm sure you would have made a Grandfather clock !
   / Making a small chain #5
That one was practice, now make out of stainless steel safety wire!
   / Making a small chain #6
James, lookin' good - now, I want you to make me a Samurai sword by welding 30 single-edged razor blades together end to end :D Steve
I haven't had any luck at all with the razor blades
   / Making a small chain #9
That looks factory :thumbsup: Great job
Thanks for all the kind comments guys.
James K0UA
2020 Kubota SVL 75-2 Skid Steer (A51573)
2020 Kubota SVL...
2022 John Deere 8RX 410 Tractor (A53342)
2022 John Deere...
JOHN DEERE 560M LOT NUMBER 15 (A53084)
JOHN DEERE 560M...
Schwing 750-15 Concrete Pump (A51573)
Schwing 750-15...
THOMPSON F4L 1011 PORTABLE DIESEL PUMP (A51406)
THOMPSON F4L 1011...
Kubota Salt-Spreader (A52384)
Kubota...
