Page 1 of 3 123 LastLast
Results 1 to 10 of 21
  1. #1
    Member
    Join Date
    Feb 2013
    Posts
    27
    Buchanan Va
    JD 4005
    Default Cheapest way to try my hand at TIG?
    I'd really like to try some tig welding, especially after seeing the pictures on this site of all your welds. I currently own a Lincoln 120v flux core that works well for my needs, considering that I don't have 230v in my garage. I am very much an amateur, and this would be basically just for kicks, but I want to learn how to do it well. In a few years we will build a new house on our land and then I definitely want to upgrade to real machines, but I enjoy doing what I can with what I have. I am currently finishing up brush forks that will hook on my FEL bucket. I won't show off any close-ups of my welds but I've never had one break (knock on wood).
    I understand the 80 amp stick welder from HF is relatively easy to set up for tig, and gets surprisingly good reviews. Would this be a good option? Any better 110v options?
  2. #2
    Super Member Shield Arc's Avatar
    Join Date
    Jan 2009
    Posts
    5,998
    Port Orchard, WA.
    John Deere, 4200
    Default Re: Cheapest way to try my hand at TIG?
    I would think any CC welder will Tig weld, all you'll need is a Tig rig, bottle of argon, flow meter, and some filler metal.
    HTP Argon CO2 MIG TIG Flow Meter Regulator Welding Weld | eBay
    Attached Thumbnails Attached Thumbnails Cheapest way to try my hand at TIG?-tig-rig-200-amp-jpg   Cheapest way to try my hand at TIG?-tig-power-block-jpg
    Miller Dynasty 300.
    Lincoln V350-Pro w/pulse.
    Lincoln LF-74 wire feeder.
    Lincoln SG Spool gun.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    Everlast PowerArc 200ST.
    3 Lincoln SA-200s.
    Vantage 400
    1800 Ellis saw.
    Hypertherm Powermax 1250, CNC table.
    PROFAX Welding Positioner.
    JD2 model 3.
  3. #3
    Elite Member dstig1's Avatar
    Join Date
    Apr 2010
    Posts
    2,805
    W Wisc
    Kubota L5240 HSTC, (Kubota L3130 HST - sold)
    Easiest way? Find a local community/technical college with a class in TIG, then take it. It will be worth more than the fee in filler rods burned alone.
    -Dave
    "Being a pessimist is great. You can't lose. Either you end up being right...or you are pleasantly surprised."
    L5240HST, QA, 824 Loader, 48" Forks, 48" Grapple, rear blade, box blade, landscape rake, Ancient Farmi Skidding winch
    Trailer - 10k/16' twin axle w/elec brakes
    2005 F250 5.4V8(3V) 3.73/4wd tow vehicle
    My house build blog: http://stighouse.blogspot.com/
  4. #4
    Join Date
    Mar 2013
    Posts
    1,844
    Edmonton, Alberta
    MF 135
    You need DC current for TIG (on steel)but what do you want to TIG weld? TIG is nice but unless you have something that specifically calls for TIG, it isn't needed very much around the farm or hobby shop.
  5. #5
    Member
    Join Date
    Feb 2013
    Posts
    27
    Buchanan Va
    JD 4005
    The thing is, I know I don't need it. I just sorta want it. However the more I read about it, the more I realize I probably won't ever get good at it because it will never be used except for practicing on scrap...
    I still would like to try the Harbor Freight stick welder though. I'll put that one on the wish list.
    Thanks.
  6. #6
    Join Date
    Jan 2009
    Posts
    5,998
    Port Orchard, WA.
    John Deere, 4200
    Tig does come in handy for quite a few things. In my opinion a Tig rig is well worth the money to have around. Here is a stainless steel to mild steel Tig weld I did with my Everlast PA-200 CC only stick machine.
    Attached Thumbnails Attached Thumbnails Cheapest way to try my hand at TIG?-powerarc200-jpg   Cheapest way to try my hand at TIG?-tig-stainless-steel-jpg
    Miller Dynasty 300.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    3 Lincoln SA-200s.
    Vantage 400
    1800 Ellis saw.
    JD2 model 3.
  7. #7
    Epic Contributor k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    27,479
    Branson, Mo.
    Kioti DK35se Hydrostat
    I use TIG for all the things that are too small/thin to be able to stick weld effectively. I don't have a MIG machine, I just use scratch start TIG on my DC stick Machine an Everlast PA160.
    Here is only one example of something I repaired with my TIG setup.
    http://www.tractorbynet.com/forums/w...id-crafty.html
    I have repaired several household items also.
    Here is something I fabbed up. using TIG
    http://www.tractorbynet.com/forums/k...lve-lever.html
    http://www.tractorbynet.com/forums/w...all-chain.html
    James K0UA
    Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. EA 50 inch single lid "wicked" Grapple. Satisfied Everlast PA160 welder owner NRA Life Member How to add a link to a post . Best way to search TBN .
  8. #8
    Elite Member Poopdeck Pappy's Avatar
    Join Date
    May 2013
    Posts
    2,568
    Dallas, Texas
    Kioti DK50SE Cab, Kubota BX23, Kubota BX2660, Grasshopper 729BT
    Is there a TIG 101 primer somewhere that I could watch/read to understand the entry-level basics of TIG welding?
    The only welding I've ever done was years ago on the farm with an old Lincoln AC buzzbox stick welder. I have no idea what is required for TIG welding or how to get started, so a "TIG Welding For Dummies" or "TIG Basics" primer would be a good start for me.
    __________________
    Pappy
  9. #9
    Super Star Member brin's Avatar
    Join Date
    Jul 2009
    Posts
    10,866
    Georgia - Mt. Vernon by The Store just 5 miles east and right by the big oak tree then to the creek.
    Just get on You Tube and type in Tig Welding....all kinds of instructional videos will come up.
    Bob
    WORRYING does not take away tomorrow's TROUBLES, it takes away today's PEACE.
    NH - TC-29 , FEL, Bush hog, Bush hog brand finishing mower, Post hole digger, 6' Back blade, sub-soiler, Pallet forks, 20KW PTO Generator , 21 hp Murray Mower
    JD -3020 with FEL and a 16 HP. K-Grow Lawn Tractor (bought from K Mart 1994) and runs great !
    Clark 130 EN Mig Welder
  10. #10
    Join Date
    Jan 2009
    Posts
    5,998
    Port Orchard, WA.
    John Deere, 4200
    Quote Originally Posted by Poopdeck Pappy View Post
    Lanse is a member here, his video will give you the basics.
    Scratch Start Tig Setup Explained - YouTube
    Miller Dynasty 300.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    3 Lincoln SA-200s.
    Vantage 400
    1800 Ellis saw.
    JD2 model 3.
Similar Threads
  1. Cheapest way to get into a toothbar
    By whitedogone in forum Attachments
    Last Post: 04-07-2012, 02:09 AM
  2. Cheapest way to try my hand at making hay?
    By beppington in forum Projects
    Last Post: 03-29-2011, 11:11 PM
  3. Cheapest way
    By boogerman2000 in forum Kubota Owning/Operating
    Last Post: 05-01-2009, 08:47 PM
  4. cheapest way to do a project
    By mlinnane in forum Projects
    Last Post: 11-18-2005, 01:15 PM
  5. CHeapest Tiller for BX?
    By r0GuE in forum Kubota Owning/Operating
    Last Post: 02-21-2005, 10:55 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
