Results 1 to 4 of 4
  1. #1
    Member
    Join Date
    Mar 2011
    Posts
    26
    Washington
    Kubota L3700SU TLB
    Default Everlast PowerPlasma 60 and PowerArc 160STH
    First freehand cut with PowerPlasma 60 on 1/4" plate. Like cutting room temperature butter!
    Among my first TIG welds (ever) with PowerArc 160STH (I didn't show the really ugly ones). Fillet weld with filler, lap welds without filler.
    Nice machines! No problems with setup and operation. I am using a Harbor Freight refrigerated air dryer with the plasma cutter. I love the foot pedal with the PowerArc 160STH. I thought it would be difficult to get the foot-hand coordination going, but it works very well. My biggest problem running TIG was that I shake like a leaf, but after reading the threads on TIG in the welding forum and watching a bunch of YouTube videos, I started to figure out what to do. The stick welder function works great. I was very pleased with the first beads I had laid in 40 years! I tried 6011, 6013, and 7018 so far.
    Still need a lot of practice, but I am quite pleased with these Everlast products! In particular, the PowerArc 160STH is a relatively inexpensive way to experience TIG welding.
    Attached Thumbnails Attached Thumbnails Everlast PowerPlasma 60 and PowerArc 160STH-welds-12-jpg   Everlast PowerPlasma 60 and PowerArc 160STH-welds-13-jpg   Everlast PowerPlasma 60 and PowerArc 160STH-welds-19-jpg   Everlast PowerPlasma 60 and PowerArc 160STH-welds-20-jpg
  2. #2
    Join Date
    Mar 2013
    Posts
    1,861
    Edmonton, Alberta
    MF 135
    Default Re: Everlast PowerPlasma 60 and PowerArc 160STH
    Looks great!
  3. #3
    Join Date
    Feb 2012
    Posts
    1,717
    Albany OR
    Case 580B, Long 460, Allis-Chalmers 160
    Ditto, good looking welds - one tip that helped me a lot with my PM45 - get a couple pieces of 1" angle, say 2 foot and 4foot to start - knock the mill scale off one outside surface with something like a flap disc (gently as possible, you want it STRAIGHT), get a couple of clamps, and measure from the side of your torch's orifice to its outer perimeter - mark that distance (for future use) somewhere on the angle irons, and clamp one of them that far away from your cut line - place the angle so its upright leg is TOWARD your torch - that will give you a straight edge, and the vertical part of the angle will help you keep the torch from TIPPING (unless you WANT your cut beveled :=)
    Keeping your travel speed at optimum for a given thickness is tricky too, but enough practice will help, and your cuts will show it... Steve
  4. #4
    Super Member Shield Arc's Avatar
    Join Date
    Jan 2009
    Posts
    6,064
    Port Orchard, WA.
    John Deere, 4200
    Personally I think you should add a lot more filler.
    Attached Thumbnails Attached Thumbnails Everlast PowerPlasma 60 and PowerArc 160STH-right-hand-9-oclock-jpg
    Miller Dynasty 300.
    Lincoln V350-Pro w/pulse.
    Lincoln LF-74 wire feeder.
    Lincoln SG Spool gun.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    Everlast PowerArc 200ST.
    3 Lincoln SA-200s.
    Vantage 400
    1800 Ellis saw.
    Hypertherm Powermax 1250, CNC table.
    PROFAX Welding Positioner.
    JD2 model 3.
Similar Threads
  1. New Everlast 160STH unpacked
    By daugen in forum Welding
    Last Post: 03-19-2013, 07:45 PM
  2. Everlast Powerarc 140ST vs tombstones
    By handirifle in forum Welding
    Last Post: 07-17-2012, 05:05 PM
  3. My Everlast PowerArc 300
    By Sublifer in forum Welding
    Last Post: 03-21-2012, 12:17 AM
  4. Everlast PowerArc 200 Arrived Today
    By Hoosier Hay Man in forum Welding
    Last Post: 01-02-2011, 10:05 AM
  5. Everlast PowerPlasma 70 review
    By gwdixon in forum Welding
    Last Post: 12-03-2010, 08:54 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
