wawajake
So I want to extend the bucket on my FEl on my BX2660 (4 ft bucket) I find in the winter moving snow the bucket could handle more that now falls off the sides and back , also in the summer for moving topsoil or woodchips.
So I stopped by the "traders metal" and got to raid their scrap bin of random pieces of 1/8 inch mild steel.
I plan on extending sides maybe 4 or 5 inches deeper and at the top I will do either expanded metal in a frame (so I can see thru ) or just add 4 or 5 inches of metal with a frame of 1 1/2 inch angle steel with 1/ 8 plate inserted.
I will use my trusty Lincoln tombstone AC stick welder , I have on hand 6011, 6013 and 7018 rod, both in 1/8 size and 3/32 size I think and some 7014 in 1/8 size that I most comfortable with ussually.
So if I take the bucket off and stick to horizontal welding to the 1/8 metal bucket, what amps and welding rod should work best . Also should I just tack weld stitches or should I do complete welds . I assume if complete welds then I shuld tack and stitch , while letting it cool alternatively around the area . I figure on using 6 inch wide 1/8 inch plate so that it overlaps the bucket by at least one or two inches.
I will round and grind the extension plate before attaching so no 90 degree corners to curl with heat.
thoughts anyone ?
thoughts anyone ?
