Results 1 to 2 of 2
  1. #1
    New Member
    Join Date
    Dec 2014
    Posts
    1
    branford CT
    none
    Smile lincoln SA-250 deisel arc welder problems
    I have a lincoln SA-250 deisel arc welder. It sat for years before I bought it. It woked great for 5-6 years and then sat for 12-18 months. When I went to use it recently,It ran fine and I have 120 volts at the aux. plug. The problem is that all I get is a very weak arc spark at the end of the rod no matter where the cotrols are. I have cleaned the brushes and terminals and flashed the exiter field with a 12-volt battery per the instuctions. When doing that i had two different instructions; one with the engine stopped and one with the engine idleing. When stopped the flashing proceedure created a min. spark. When flazshing at idle I got a large spark at the exciter brush term which was supposed to happen. After all of this it still acts the same. Where should I go next? MOD-SA-250 CODE-8305 SER-925510
  2. #2
    Elite Member Shield Arc's Avatar
    Join Date
    Jan 2009
    Posts
    4,517
    Figuring the picking points of jelly donuts.
    John Deere, 4200
    Default Re: lincoln SA-250 deisel arc welder problems
    And you say the brushes are floating freely up and down in the copper holders?
    Attached Thumbnails Attached Thumbnails -brushes-jpg
    Miller Dynasty 300.
    Lincoln V350-Pro w/pulse.
    Lincoln LF-72 wire feeder.
    Lincoln SG Spool gun.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    Everlast PowerArc 200.
    Everlast PowerArc 300.
    3 Lincoln SA-200s.
    1800 Ellis saw.
    Hypertherm Powermax 1250, CNC table.
    PROFAX Welding Positioner.
    JD2 model 3.
Similar Threads
  1. Lincoln Power Arc 5000 AC Welder
    By jlgurr in forum Welding
    Last Post: 06-06-2014, 11:29 AM
  2. Lincoln Idealarc 250 - problems with power to leads
    By soapthedog45 in forum Welding
    Last Post: 09-28-2012, 09:23 AM
  3. Lincoln - ARC welder price?
    By Canada_CT230 in forum Welding
    Last Post: 12-13-2011, 02:29 AM
  4. Replies: 5
    Last Post: 06-09-2011, 05:26 PM
  5. Replies: 29
    Last Post: 01-14-2011, 09:33 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2014 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
