bumperm
I have a newer Country Line (TSC) landscape rake. While picking up some rock with FEL, I managed to back into a tree with the rake, twisting one side of the tine bar so the tines are forward and lower on that side (the main C channel is still about level but torqued maybe 20 degrees of rotation) tines not damaged. I tried hooking the now lower tines on the bent side to the edge of a concrete driveway and driving forward - that helped some, but not a lot.
Problem is the C channel tine carrier is welded to its center pivot and that is welded to the top plate that has the angle adjusting holes - nothing comes apart without cutting steel, so it is not at all convenient to put parts in my hydraulic press to straiten things. Also, the rake is too heavy to manhandle easily. I have a plasma cutter, so could lop off the bent part and either buy a piece to weld back on or straighten out the bent bit (either hot or cold), but I guess if I were trying to heat it to cherry to bend it back, then there might not be a lot of sense to cutting if off first.
I also have a port-a-power, but can't conjure up a way to hook things up to use that to straighten it.
Any thoughts or ideas appreciated - hopefully I'm overlooking something . . .
