Hilbilly,
There are a number of pages of cut charts in your Powermax30XP operators manual that provide suggest power levels and approximate cut speeds. Here are some details and suggestions:
- The 30XP will run on 120 volt or 230 volt input. The Finecut parts were designed to use lower airflow as well as a lower arc voltage......which allows for lower input amperage draw even when cutting thicker materials.
- You can use the Finecut parts at the full 30 amp output, however if running on 120 volt input power you will trip a 20 amp circuit breaker after 10 to 20 seconds of cutting, maybe quicker on thicker materials (higher arc voltage).
-If you set the amperage output at 20 Amps when using the Finecut consumables.....you can cut continuously on a 20 amp, 120 volt power circuit without tripping the breaker.
-The Finecut parts are not shielded like the 30 amp standard parts. Excellent cut quality with a very narrow kerf can be expected with these , but somewhat shorter nozzle orifice life as compared to the standard shielded parts. I use them when I need best cut quality, and when I need to operate on a 120 volt, 20 amp input circuit.
-Yes, the Finecut parts will wear out faster at 30 amps as compared to when operating them at 20 amps.
-If you have a 230 volt input circuit connected the standard parts are the most powerful (thickest and fastest) and will last the longest when running at full output power.
-You certainly can use the Finecut parts when running on 230 volt input power. Use them when you need slower speeds (intricate cutting on thin materials).
Jim Colt Hypertherm
I've got a Hypertherm 30xp and have been using it a fair bit lately (hobby use). The other day I used the fine cut nozzle on 120 v and was surprised at how fast it cut through 3/16" plate at a 20 A setting. I usually run it on 240 V using the general cutting tip and leave the amperage setting all the way up (30A). My question is, should I be adjusting the amperage for different thickness metal or just leave the amperage at max? Are there any advantages / disadvantages to using a lower amperage setting, other than having a higher duty cycle on lower amperage settings? Will my consumables be damaged faster by using the max setting on thinner materials?
