It is definitely not stainless. This stuff is the same thickness as Sched 40 pipe but is a different material. I think it is gas pipe and the coating is not paint.
I'm making a forge based on the Whitlock design and I'm using this pipe for the internal air flow selector. I used the unfinished forge to heat up the pipe to burn off any chemicals or coatings on the pipe but was amazed that the coating burnt but still did not flake off even at around 1600* F. I couldn't even scrape it off after that much heat. I will end up having to use the grinder to get it off.
I've used the forge a few times already without the air flow selector but I think it will be better with one. I'm in the process of making my first set of tongs using my newly completed anvil. Man anvil making is time consuming. If I remember I'll get a pic of the anvil and forge tomorrow.
