dragoneggs
Super Star Member
- Joined
- Jun 9, 2013
- Messages
- 14,617
- Location
- Seabeck, Washington
- Tractor
- Kubota BX-25D, Kubota Z122RKW-42
Why do fume extractors cost so much? Are there inexpensive DIY solutions that work?
Probably lawyers and OSHA.Why do fume extractors cost so much? Are there inexpensive DIY solutions that work?
FROM Homemade Fume Extractor For About $100 - Miller Welding Discussion ForumsThe fume extractors I’ve seen online are pretty expensive and their cfm’s are not all that good for the money. I've been checking Craigslist for one for a while with no luck so I decided to build my own fume extractor today.
I used 3 50cfm bathroom fans for a total of 150cfm. I bought the cheapest ones I could find - $13.97 each at Home Depot. I wired them in series and installed an on/off switch. I made a manifold to vent them all together and used a 4" enlarger/reducer for the exhaust (the fans have 3 inch outlets). I made a bracket to attach the unit to my Stronghand Tools Nomad welding table. I made the bracket removable so I could detach it whenever I want to. The whole project cost me $93 + tax. I did some stick and flux-core welding today for about 2 hrs. and it worked great – better than I had hoped. What a pleasure it is to weld without all that smoke!
I keep reading about this danger but I see so many people rig up fans to ventilate their shop that are cheap and not explosion proof. But I hear you though! Just wondering for light duty DIY shop type of set up, do you need a $2500 or higher fume extractor?For safety reasons the motor is usually required to be explosion-proof- totally enclosed fan cooled (TEFC) which costs more than your average blower motor. The blower wheel and housing are also epoxy coated or made of a non-metallic material. Static electricity can easily be created within the blower housing as well as the exhaust ducting which can cause ignition of any flammable gases, vapors, or dust particles in the airstream.
No that's what he's trying to say is that stuff that is marketed for that use is required to meet a list of requirements of osha for approve it, that list requires it to function in situations that you will never create in your home shop.I keep reading about this danger but I see so many people rig up fans to ventilate their shop that are cheap and not explosion proof. But I hear you though! Just wondering for light duty DIY shop type of set up, do you need a $2500 or higher fume extractor?
