Oldoak
- Joined
- Feb 20, 2013
- Messages
- 1,810
- Tractor
- Kubota L5060GST, J D X758 GT, J D 855D XUV
If your are not tripping the circuit breaker, I don't believe the extension cord is causing the problem. Keep in mind the distance the plasma torch tip is held to the metal being cut is just as important as the cutting speed as well as the correct pressure setting.
Just a side note. In an industrial setting, we had always found it was easier to make cleaner cuts on stainless steel and other alloys than it was on carbon steel with a plasma cutter.
