Dadnatron
Just took my 1st official welding 'class'. Actually, its basically just proctored booth time.
I was introduced, on my 1st day, to Spray arc. Now, this was a very interesting technique, of which I've heard but have no experience. He set up the machine in such a way, because I had told him my goal in this class is to become more proficient at farm repair with some fab work thrown in.
I was only there for about 2hrs and during that time, I was simply running beads on scrap plate.
My questions for you are:
1. What is the most 'portable' size machine which would be likely capable of spray arc technique? I understand the 'basics' however, I don't know what sort of 'size/amperage/voltage' machine would be required. I was using a Miller 350P, I believe. Actually, I guess what I am asking, is what 'voltage' is typically required to get spray arc with a given wire size. And, while I was using .045 wire yesterday, is there a benefit to doing so, on a farm. The wire was larger than any I've seen used before, but I've also not used that 'heavy' of a machine before. What wire size would you 'max out' at for a typical farm repair for a novice?
2. I understand that spray arc requires good metal cleaning. And I understand that most things that can be done with spray arc can also be done with short circuit. Is there a benefit to one or the other? I really liked that there was essentially no spatter, and even I could make a decent looking weld, after a few tries. (my travel speed inconsistency certainly would show up easily).
3. I've read the 'spray arc' threads (or at least what has been linked) on Welding web. I really liked the technique, and felt relatively confident in it after a bit. However, if the 'machine required' is simply more and or more $$$ without really giving me, as a farm repair with some fab work, a real benefit, I don't want to head down that path right now. In a perfect world I'd have a portable machine for field repair and a big machine in my shop. However, my current shop is a storage shed and all welding is done outside.
4. I also recognize the heat developed, and that it cannot be used on thin material. But how 'thin' is typically 'too thin' for spray arc? I recognized that the gloves they had available weren't really designed for a lot of spray arc welding. I just noticed a very small blister on my left wrist, which must have been too close to the heat for too long.
Basically, is spray arc worth my time, given my situation?
