Welding Table
   / Welding Table #1
KennyG
Elite Member
SW Michigan
John Deere 2320
I really admire the fabrication tables some of you have but I can't really justify all that for the welding I do. I did, however, recently make a small welding table out of a salvaged Craftsman table saw. I bought the worn out table because I have the same model and needed the fence and work guide. I stripped the guts out of it and added casters from a $8 Harbor Freight furniture dolly. When I find the right material I will replace the wood shelves with metal. It's pretty handy for welding small stuff and as a general work table.
In addition to the parts I needed, the old saw had a new fine tooth blade and the motor seems to run OK, although I'm not sure what the keyway will look like when I finally get the pulley off.
   / Welding Table #2
Kenny:
I have 5/8" round holes in my welding tables to accommodate clamps. You could most likely utilize the miter slot on your table to do the same.
MINE:
I made a little mockup to illustrate yours:
Weld a clamp body to a piece of 3/4"x 3/8" flatbar about 2" long. In order for it to work the clamp should be welded at right angles to the LENGTH.
If it doesn't work I'll happily refund your money
   / Welding Table
Clamp idea looks interesting. I will probably try it.
   / Welding Table #4
Looks like you could also quite easily add bolt-on extensions to increase your work area.
   / Welding Table #5
Kenny:
MINE:
I am interested in your 5/8 hole clamp idea. Is there a nut on the underside of the vertical shaft. A cross section picture may be of value in doing something similar. Saves welding hold downs like I usually do and then have to grind away after.
Ron
   / Welding Table #6
Ron. No nut on underside. Just 5/8” round stock inserted into a 5/8” hole. The table top would prob need to be 1/4”-3/8”minimum thickness.
As the clamp’s screw is tightened down the vertical axis of the clamp is tilted creating a binding fit.
Not a system suitable for OCD types as when in use the clamps aren’t perfectly vertical. *
*see my photo in earlier post
   / Welding Table #8
Here is my version of a welding table for occasional use that doesn't take up much space. When I use it for cutting with a plasma cutter I arrange the piece so the cut is between the grooves.
Here is where it normally lives.
This shows the tubing that I welded on the bottom of the grating that fits in the notches of the cheap plastic Stanley saw horses.
Ready for use.
   / Welding Table #9
Very nice! IF that grating is galvanized you don't want to be breathing the fumes though.....
   / Welding Table #10
Amen. We used to call it "zinc flue". It's nasty (but not as deadly as cadmium fumes.)
