square1
Picked up a used bandsaw yesterday. The band on it id pretty fine toothed (14~18 TPI) and the seller said it was probably dull. Set it up and cut some 2" galvanized pipe with ~1/4" wall (standard house drain type stuff). It took several minutes, but did make a nice clean square cut.
The first project is to cut off several rods that are welded to 1/4" angle off through the weld. Made it a bout 1/2 way through the first cut and that's all she wrote. Ordered up some new blades (Cobalt and M42 Bi-metal) but am wondering if cutting through welds like this is going to destroy them. Thoughts?
