KYErik
- Joined
- Dec 2, 2005
- Messages
- 893
- Location
- South central IL
- Tractor
- 1977 AC 7000, 1980 JD 2840, 1963 Case 930, 1963 Ford 4000, 1943 Case SC, Case 530CK backhoe
I am repairing some 1/8" stainless. It is an ear that holds the 7/8" pivot pin of a swinging auger on a fertilizer tender (so it will need to be fairly strong). The ear was damaged when the pin fell out while driving down the road and the auger landed on the ear and folded it over. I did my best to straighten it, but it needs some serious reinforcing and the hole is out of round.
My two options/ideas are:
1. Buy an extra thick 7/8" id stainless steel washer and weld it on/over the hole to tie everything together. I will have to order such a specialized part.
2. Buy a regular steel 7/8" id washer (easy to buy locally) and weld it around the hole.
Any advice or better ideas? I have an AC/DC stick welder. Would I use a standard stainless steel repair welding rod for either of the two above options?
