cabinhollow
When I start getting back to back shut downs due to ( can not detect metal ) code, even with cleaning the consumables after each shut down.How do you know when you need to change the consumables while cutting a large order? Thanks, I'm just curious.
It can be as little as 5000" or over 10,000".
Overall the cost is so low per gross output, that I change them alot of the time before they go bad. Then I use them in my hand held torch.
I check last year and I had 20+ lbs of used consumables.
