Sodo
Elite Member
- Joined
- Apr 21, 2012
- Messages
- 3,197
- Location
- Cascade Mtns of WA state
- Tractor
- Kubota B-series & Mini Excavator
I ran a 120v MIG welder for years on generators with 3200 running watts, and it can weld up to 3/16". A modern 120V MIG will weld 3/16" with absolutely NO problem. Very nicely. Here's a 120v MIG project:
http://www.tractorbynet.com/forums/build-yourself/355190-moved-trailer-jack-so-tailgate.html
For a 240v welder on a generator, you need at least 7,000 running watts to weld 3/8" steel (at 240v). If you plug a 120v welder into a 240v generator you are only using HALF the generator. So you only get half the watts. So if the generator is 7,000 watts, out of the 120v plug you only get 3500 watts. 3500 watts is enough for 3/16" steel. If you want to weld 1/4" steel with a 120v MIG you need an 8,000 watt generator (to get 4,000 at 120v). Got it? This is generator talk, not plugged into the grid.
So, if you are running in a generator, get a 240v welder so you can use the whole generator. A 120/240v (dual voltage) welder is a great feature though.
If you get a machine with 20% Duty cycle its plenty. It will never shut down on you. And you'll never actually meet someone who has ever had a duty cycle problem. On the internet everyone's a pro welder, every job a pro situation, boss crackin' the whip, max thickness metal, max amps, max speed etc. In reality that situation is pretty sparse. These fellas are welding cracks in their lawnmower decks, and burning holes. Duty cycle ain't a concern, its just internet talk, you'll never see it in real life. Especially as a beginner. If you ever turn pro, well you'll have pro eqpt, andwon't have to discuss duty cycle there either. Basically if you never again utter the words "duty cycle" you will never need to. Unless buying $89 harbor freight welders.
Get an everlast PowerMIG 140E if 120v. Or next size up with 120/240. Any used Miller, Hobart Lincoln MIG will do you fine. Around $500 the 120v MIGs are good. 240v is a little higher but they weld great and last forever.
