I do not weld but thought this would be a good place to ask about angle grinders.
I'm looking for my first angle grinder and originally thought a variable speed a/g would be better than a single speed, but do I really need variable speed ?
I'd use the a/g to cut off steel (probably 1/4" thickness or less), sand rough metal edges, and wire brush paint from steel.
I'd also sharpen mower blades for my 72" rear mount finish mower (3 big blades) and two 42" deck (3 blades each) from my rider mowers.
and there's probably other jobs I've over looked.
I'm considering either the Makita 9565PCV variable speed
or Metabo WP9-115.
Makita 9565PCV
https://www.amazon.com/Makita-9565PC...70_&dpSrc=srch
Metabo WP9-115
Metabo WP9-115 Quick 8.5 Amp 1 , 5 rpm Angle Grinder with Non-locking Paddle Switch, 4 1/2" - - Amazon.com
What do you suggest ?
thank you
or Metabo WP9-115.
Makita 9565PCV
Metabo WP9-115
thank you
