Currently theres a lot of nostalgia for Stick welding, it must be trending on Facebook or something
Pretty sure Millermatic 200 is the machine I learned to MIG on. This was back in 1981. Summa you fellers think that was only 10 years ago (it was 37 years)! Its a classic. Im waiting for the day when some young feller assumes Im a real welder cuz I talk about running a MM200 back in the day. Thats about 5 years out I think (check back in 2023
Be sure to post pics of your thoughts and progress. I stick-welded again after 36 years, it was great fun, like a sport and was great to know I can fall back on it. Skills were still there like riding a bicycle, but it the new machine (Miller MultiMatic 200) is a DC inverter and actually EASIER than an old buzz-box. But its no substitute for the MIG. If youre the type to repair stuff there will be lots of things you cant repair anymore. So youll have to learn the TIG. Which aint a bad thing, other than time-consuming. And which may be OK if you have the time & interest. Always learn new processes, even if you dont use it much it could improve the processes you DO use.
Bought my 200ST last August. Had a ac buzzbox before that. All you need to setup for tig is an air-cooled torch, regulator and argon. If you want to weld aluminum, you will need a bottle of helium
Helium is for DC tig. Choosing an AC tig for Aluminum (using your one argon bottle) will save a lot of $$$ & hassle.
Works fine on 120v but will have less power (amperage range) but will get you by. I have welded in the field off a 5k generator at 120v. It does run better at 240.
It runs better on 240v for a good reason. One thing to remember about welding with 120v on a generator. A 240v generator that has a couple 120v outlets
that each use only one leg (HALF of the windings) of the generator. The other leg is the other 120v outlet (the other windings are idle, un-used). Consequently a 5kw 240v generator is only 2.5kw at 120v. 2.5kw is good for appx 1/8? You want about 3.5kw to weld 3/16 or 1/4? So to weld on 120v youll need a 7kw (or 8kw). Whereas if you had a 240v welder it would use both legs (the whole generator output).
Sorry for the confusion but confusion is one of the reasons 120v doesnt work well for remote welding. Its a really simple reason that confuses people into thinking its a problem with a 120v welder. Its not the welder - its a problem on the plug-in supply. A problem that simply goes away with 240v. Dual Voltage welders are handy if you cant just put 240v everwhere you might weld.
