Page 6 of 6 FirstFirst ... 3456
Results 51 to 57 of 57
  1. #51
    New Member
    Join Date
    Mar 2008
    Posts
    23
    Yulee and Hilliard,Fl
    Default Re: New Yanmar-Cub CUTs
    Wait until you guys drive one of these............the first product of this JOINT venture.
    Built in the Yanmar plant in Georgia.
    Serving Northeast Florida and Southeast Georgia with the finest in tractors and outdoor power equipment.
    BushHog,Kioti,CubCadet-Yanmar tractors and implements. CubCadet,Exmark,Gravely,Toro and Stihl outdoor power equipment.
  2. #52
    New Member lorus1966's Avatar
    Join Date
    Mar 2008
    Posts
    24
    Wisconsin
    2008 Cub Cadet Yanmar SC2400 and one very tired JD 318.
    I've got one of the 24 hp units and have put about 10 hours on it so far. I really (REALLY) like the layout of the machine and the overall quality. I considered getting the 32 hp machine, but with my knees I would have been really hurting climbing up and down all the time. The SC2400 is very easy to get on and off.
    The loader design seems to be well thought out and so far has moved some nicely sized boulders around the property. I've filled the rear wheels with Rim Guard and have a 300# cement ballast for the 3 point. It seems very steady on the rolling ground around here.
    Not terribly impressed with the traction of the R4s in the mud though, and will be picking up a set of chains for the rear wheels this week.
    What would I change? Coming from a JD 318, everything is taking some getting used to. So far I find that I very much miss having split brakes. My JD 318 had them, and there have been a number of times that I've already needed them, most noticeably when back-dragging with the loader. Even a slight lift on the front end does away with steering ability, and being able to lock one of the rears would be nice. Apparently it's common on the SCUTs to not have the split brakes, but it would be nice. The other thing that's apparent is the lack of a toolbox. They should have found a place to store all the necessary pins, clips, etc. My solution so far is to use a soft-sided toolbag shoved under the seat.
    I've added a rear-facing work light and a beacon for the top of the ROPS so the cars don't smack into me when I work along the road frontage.
    I'll post some pictures as soon as I figure out how.
  3. #53
    Silver Member EmerichSales's Avatar
    Join Date
    Jul 2000
    Posts
    192
    Here is a couple of pictures of the New Cub Cadet Yanmar SC2400 and Kubota BX2350V side by side
    Kevin
    Attached Thumbnails Attached Thumbnails New Yanmar-Cub CUTs-bx2350v-sc2400-1-jpg   New Yanmar-Cub CUTs-bx2350v-sc2400-2-jpg
  4. #54
    Join Date
    Jul 2000
    Posts
    192
    Comparison between the Kubota BX2350V and the SC2400 Cub Cadet Yanmar Sub-Compact Tractors
    Kubota is 54.8 Cu In engine
    Yanmar is 55.1 Cu In engine
    Kubota is 1322 lbs
    Cub Cadet Yanmar is 1280 lbs
    Kubota 3pt lift 24" behind pin is 670lbs
    Cub Cadet Yanmar 24" behind pin is 661lbs
    Kubota Fuel Tank is 6.6Gal
    Cub Yanmar Tank is 5.8Gal
    Kubota LA243 is 1st numbers and Cub Yanmar CL100 is 2nd set of numbers
    Max lift height at bucket pin 71.3 in - 71 in
    Dump clearance 52.4 - 54
    Reach @ Max Height 28.9 - 28.5
    Dump Angle 45 degrees - 45
    Digging depth 4.7in - 6 in
    Bucket width 48in - 48in
    Raising time to full height w/o load 3.5sec - 3.5
    lowering time w/o load 2.7sec - 2.5sec
    bucket rollback 2.4 - 2 sec
    bucket dump 1.7 - 1.5 sec
    Rated Flow 3.7 gpm - 3.5 gpm
    Relief valve PSI 1778 - 1780 PSI
    Lift Capacity 500mm fwd max height 518lbs - 550lbs
    Lift Capacity pivot pin max height 745lbs - 700lbs
    Kubota Breakout Force 500mm fwd 992lbs - Cub is measured at pins 1350lbs
    Kevin
    Emerich Sales & Service inc
  5. #55
    Bronze Member bsinhc50's Avatar
    Join Date
    Oct 2007
    Posts
    50
    South West PA
    Yanmar Ex3200
    I've had a SC2400 for about a month now and I'm very pleased with the machine. It has enough hp to do what I need done, is very manueverable in tight spaces, and the ergonomics for the driver's area was well thought out, especially for a guy my size (I'm 6'3", 245lbs). The only thing I'm having problems with is the top link of the 3ph. As it sits now, I must have the top link totally wound in to hook up to the blade but in doing so, that allows no more than 4 inches of ground clearance for the bottom of the blade. I've brought this to the attention of the dealer were I purchased the machine and he contacted Cub Cadet about it. In the research I've done, on another forum and on other brand machines, it appears to me that the top link should be mounted lower on the rear of the tractor which would allow it to be opened up when it's hooked up to a 3pt implement. If anyone has any ideas, Please don't hesitate to pass them on. All ideas and/or thoughts are appreciated.
    Bill
  6. #56
    Join Date
    Jun 2006
    Posts
    839
    Northern Alabama
    2012 Kioti DK45SE, 1994 JD LX176
    See if you can find a shorter top link, maybe TSC, local Co-op, etc., or search on the internet. Maybe your dealer can provide one.
  7. #57
    Join Date
    Mar 2008
    Posts
    24
    Wisconsin
    I've noticed the same thing on my SC2400, not much ground clearance under some implements when they are raised. I decided against a shorter top link though after using the box blade. When doing the final passes with the box blade I had the top link all the way out. A shorter top link wouldn't have worked for this.
    I think that the problem has nothing to do with the top link. I think that the problem is that the machine is a SUB compact and sits low to the ground. I have noticed a huge difference when using implements designed specifically for sub compacts machines, like the XB line from King Kutter. If your blade is meant for a CUT and not a SCUT, there's not really much that will help.
    Of course, even with the XB implements there are still limitations. Take the middle buster for example. In order to have any usable depth to the cut, there is a limit to the height it will raise up. We have a lot of hills, and the only way to transport the middle buster without scraping the ground is to either take off the blade in for transit or just carry the whole works in the FEL until I get to the garden.
    I've got an XB 5' blade, and it sits plenty high for transport in the center position. If I angle it all the way though, the bottom corner catches on even a slight incline.
    All that being said, I love how low the machine sits for two main reasons. 1) My knees would scream constantly climbing into anything larger, and 2) The lower height means more stability on all of our hills and slopes.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
