Results 1 to 7 of 7
  1. #1
    Gold Member
    Join Date
    Apr 2010
    Posts
    332
    Pennsylvania
    Yanmar sc2400 TLD, 1989 Ford 2120 with loader
    Default sc2400 500 hour service
    Anyone replace the gear oil in the front axel?
    Just ticked over 500 and IIRC that was something on the schedule.
    Anything to avoid? Tips? Tricks?
    Nothing that needs to be done immediately. But I intend to do it within the next month or two.
  2. #2
    Gold Member
    Join Date
    Apr 2010
    Posts
    332
    Pennsylvania
    Default Re: sc2400 500 hour service *UPDATE*
    I changed the gear oil this morning at about 530 hours.
    I will post pics with some comments later.
    One issue has come up.
    My owners manual and technical manual both say 2.6qts of 80w90 gear oil.
    When I filled the axle it only took about 1.6qts.
    I checked the drained oil and it's about 1.5qts give or take.
    Other than a misprint, and ideas?
  3. #3
    Join Date
    Jun 2004
    Posts
    697
    Quote Originally Posted by Gods Country View Post
    When you drain oil it doesn't all come out, especially heavy 80w90 gear oil. All the gears remain coated with oil. Whether 1 whole quart would remain, I don't know, but that's at least part of it. Some mechanisms like automatic transmissions give a refill quantity and also a "dry" quantity for a new or rebuilt unit.
    Bob B.
  4. #4
    Gold Member
    Join Date
    Apr 2010
    Posts
    332
    Pennsylvania
    Quote Originally Posted by Bob_Bainbridge View Post
    Bob B.
    I agree with your premise, but there is no way nearly 1/2 of the alleged fluid capacity is remaining behind. The oil was surprisingly thin after a good warm up period. I did leave both drains open for at least an hour for this reason.
  5. #5
    New Member
    Join Date
    Mar 2013
    Posts
    3
    Snohomish, WA
    Yanmar SC2400
    There's two versions of the 2400. I wonder if the axle changed when they did the rev. If so, that might explain part of it.
  6. #6
    Gold Member
    Join Date
    Apr 2010
    Posts
    332
    Pennsylvania
    Quote Originally Posted by sheetbend View Post
    Possibly, but the 2450 didn't exist yet when I purchased my 2400.
    Yanmar does make a lot rebranded stuff, so who knows. The 2400 is a pretty close clone of the jd 2305.
    I do plan on contacting Yanmar at some point.
  7. #7
    Gold Member
    Join Date
    Apr 2010
    Posts
    332
    Pennsylvania
    Default Re: sc2400 500 hour *UPDATE WITH PICS*
    So, pretty straight forward procedure.
    Just like changing the oil.
    sc2400 500 hour service-img_0462-jpg
    sc2400 500 hour service-img_0463-jpg
    sc2400 500 hour service-img_0464-jpg
    changed the oil at about 533 hours
    sc2400 500 hour service-img_0466-jpg
    The swirls appeared to be very fine metal particles.
    It was nothing I could feel, but there was a lot.
    I've changed differential oil plenty of times and never saw this.
    No major concern on my part. However my manual does not have changing the oil
    at 50 hours listed, which I found odd, and against my better judgment I did not.
    I would recommend a 50 or 100 hour axle oil change.
    I think I will let it go a while and do another change around the end of the summer to try and get some more crap out of the oil.
    I do have a lot of 4wd bucket hours on the machine... at least half of the machine hours, so I think changing the oil every 250 is not a bad idea.
    It's easy/cheap, and can't hurt.
    sc2400 500 hour service-img_0467-jpg
    sc2400 500 hour service-img_0468-jpg
Similar Threads
  1. 600 hour service
    By tdearstine in forum Kubota Owning/Operating
    Last Post: 12-03-2010, 09:22 AM
  2. Sc2400 50 hour service
    By gtrippleb in forum Yanmar (New)
    Last Post: 11-18-2010, 09:16 AM
  3. Resurfaced 500' of Road Today
    By Gordon Gould in forum Owning/Operating
    Last Post: 07-04-2010, 10:29 PM
  4. 50 Hour Service
    By garbageman in forum Kubota Owning/Operating
    Last Post: 04-28-2004, 10:22 PM
  5. 50 Hour PT Service
    By pajoube in forum Power Trac
    Last Post: 07-18-2002, 12:26 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
