HELP!! Yanmar SC2400 lost reverse!!
   / HELP!! Yanmar SC2400 lost reverse!! #1
jphillips
Bismarck, ND
Yanmar sc2400
I need some help guys!
I have a 2012 yanmar sc2400. I hauled it on a trailer about 5 miles to do some tilling at a friends house, when I got there my tractor would not go into reverse! It worked fine when loading the tractor on to the trailer but now nothing!
There are only 45 hours on the tractor, I have checked the fluid levels, and the linkage all looks good. it goes fine in forward and there are no unusual noises. all the other hydraulics work fine lifting the FEL and 3 point. the pedal seems to have the appropriate about of resistance both forward and back. the pedal stop is in the same place, and it touches the edge of the opening in the floor anyway so it can't go any further. I am stumped.
Thanks for any help!
   / HELP!! Yanmar SC2400 lost reverse!! #2
Had this happen with my Yanmar YM2610 two months ago. Except, I lost forward and reverse. Trailered it 2-1/2 hours down the road to the dealership. Guess what, all of that bouncing put the parts back into place. It drove just fine ever since. Not sure if you need to retrailer yours OR just lift up the end of the tractor that was upward when loading it.
Odd that with only 45 hours on the meter for this to happen.
Thank you very much, I was looking for this info on line and could not find anything!
hopefully it is just something loose.
   / HELP!! Yanmar SC2400 lost reverse!! #5
   / HELP!! Yanmar SC2400 lost reverse!! #6
I am also having trouble. I was driving forward with my SC2400 and was pulling a doghouse out of the snow, when it was time to go backwards I had lost my reverse.
I have forward like normal with full speed and no weird sounds etc, the reverse petal seems different almost like it is missing tension. I also do not have any fluid leaks.
I read somewhere about the HST lever but cannot find where that is.
   / HELP!! Yanmar SC2400 lost reverse!! #7
Did you read the links in the previous posting yet?
Not sure if the SC2400 has a hydraulic filter screen that needs to be cleaned. Typically that is what Yanmar tractors have.
If the tractor goes forward then the hydraulic pump is working just fine.
My fix was just plain weird. Even after cleaning the hydraulic filter, it would not shift forward or in reverse. BUT, the pump did work. Upon loading the tractor onto a utility trailer up the rear deck ramp and back down later, the problem had corrected itself. The dealer service tech mentioned that something must of jarred the problem loose to shift normally again. That was months ago without any re-occurring issues.
   / HELP!! Yanmar SC2400 lost reverse!! #8
Sounds like your reverse check valve went out. If you check with your local dealer you should be able to get this handled under warranty.
   / HELP!! Yanmar SC2400 lost reverse!! #9
Here are some additional documents. If you have a problem viewing the pdf files in this thread you can save the files to whatever device your viewing this thread on. It seems there might be an issue with these links going through viglink and then to the file.
CHAPTER 5. POWER TRAIN-HYDROSTATIC 3. Theory of Operation
Page 31 in this document shows where the reverse check valve is located.
CHAPTER 5. POWERTRAIN-HYDROSTATIC 6. Repair 6-1 Disassembling Procedure
CHAPTER 5. POWERTRAIN-HYDROSTATIC 6. Repair 6-2 Assembling Procedure
MODEL 14C SCRAPER (A58216)
MODEL 14C SCRAPER...
2015 Peterbilt 367 National Crane NBT55 4 Section 102ft. 55 Ton Quint Axle All Terrain Crane Truck (A55973)
2015 Peterbilt 367...
3PT HAY FORK (A52708)
2006 SKYTRAK 6036 TELESCOPIC FORKLIFT (A52708)
2006 SKYTRAK 6036...
2019 ford Explorer AWD SUV (A56859)
2019 ford Explorer...
RAYCO C120RA FORESTRY MULCHER (A52709)
RAYCO C120RA...
