Results 1 to 9 of 9
  1. #1
    Join Date
    Jun 2007
    Posts
    107
    Central, MO
    YM2310D
    Default 3 pt lift capacity
    Can someone tell me the 3 point lift capacity of a 2210D?
    I am curious on whether it will lift a 750 lb tiller and / or rotary cutter.
    Thanks
  2. #2
    Platinum Member Tom_Veatch's Avatar
    Join Date
    Oct 2003
    Posts
    521
    Wichita, Kansas
    Yanmar 2220D
    Default Re: 3 pt lift capacity
    Quote Originally Posted by kfin
    Thanks
    Can't speak directly to the 2210, but the operations manual that came with my 2220D shows a lift capacity of 1168 lbs at the lower link hitch point and 816 lbs 24" aft of the hitch. I assume the capacity for the 2210 would be similiar. Actually, the listings in my manual are YM226D which I assume is the US equivalent model. A couple of assumptions there that you might be cautious about.
    The lift capacity would definitely depend on how far aft of the lift the center of gravity of the implement was located. The further aft, the lower the capacity. Those two values above would allow you to calculate the lift capacity for any c.g. location:
    Lift Capacity in Pounds = 1168 - 14.7*D
    where D is the distance in inches aft of the lower lift hitch point.
    Hope this helps, or at least gives you some idea about the magnitude of the lift capacity for your tractor.
    Tom Veatch
    Wichita, KS
    USA
  3. #3
    Super Star Member California's Avatar
    Join Date
    Jan 2004
    Posts
    10,022
    Sonoma County
    Yanmar YM240, and now just one YM186D
    Thanks
    How high do you need to lift it?
    You will be near rated lift capacity and some of the lift will be lost in making the tires squat down. Those implements sound a little oversize for that tractor.
    You are sure to need maximum ballast on the front if you don't already have a loader.
  4. #4
    New Member royeakins's Avatar
    Join Date
    May 2007
    Posts
    8
    South East Missouri
    YM2310D
    Thanks
    I have a YM2310D, I use a 6' bush hog and a 6' Shibura tiller. I have no problems lifting either.
    YM2820, Koyker 160 fel, 6' Bushhog, 6' Box Blade, 6' Finish Mower, LMC Boom Pole, 6' Tiller, LMC Hay Spear
  5. #5
    Veteran Member Travis_R's Avatar
    Join Date
    Jun 2004
    Posts
    1,412
    South Louisiana
    '98 MASSEY FERGUSON 231
    royeakins,
    How does your 2310 run that 6' bush hog? If I had to guess, I'd have to say that it would put a pretty heavy strain on it.
    Just curious,
    Travis R
    '98 Massey Ferguson 231
  6. #6
    Join Date
    Oct 2003
    Posts
    521
    Wichita, Kansas
    Yanmar 2220D
    Quote Originally Posted by California
    ...some of the lift will be lost in making the tires squat down. ...
    You're talking about lift distance? I don't see where tire deflection would affect the weight (actually, moment) the 3pt could handle. But, I could be missing something. Wouldn't be the first time.
    And, I agree that he's getting pretty close to the max. The tiller, being close coupled, shouldn't be much of a problem, but the c.g. of the cutter is going to be at least 2 1/2 to 3 feet aft of the hitch point - and that could, depending on the weight of the cutter, be a problem.
    Tom Veatch
    Wichita, KS
    USA
  7. #7
    Join Date
    Jan 2004
    Posts
    10,022
    Sonoma County
    Quote Originally Posted by Tom_Veatch
    Not the weight, but tire deflection reduces ground clearance under the lifted implement. This 6 ft disc shown here is supposed to weigh 685 lbs and I first ballasted it up to about 800, where I could just lift it. But I discovered I couldn't turn sharply, which is essential in this old orchard that has some trees growing away from their theoretical grid location. After gouging a couple of trees, I reduced the ballast back to where I had better control over the steering. Even with one brake locked, the dragging disc, even fully lifted, acted like a rudder and I literally plowed straight ahead. I think the inch or so deflection I saw at the tires multiplied to several inches at the disc axles, enough that the disc pans controlled the steering even with the front tires still on the ground. If he doesn't approach the limit of lift capacity, he would never have this problem.
  8. #8
    Join Date
    May 2007
    Posts
    8
    South East Missouri
    YM2310D
    Quote Originally Posted by Travis_R
    royeakins,
    Just curious,
    Travis R
    I do alot of bushhogging with it. Under normal cutting conditions it does great. If I am into something really heavy or into some sappling I will have to slow down. If I am mowing off a sage grass field I am mowing in 3rd range and in 3rd gear.
  9. #9
    Join Date
    Jun 2006
    Posts
    92
    ALABAMA
    Kubota GL3240
    According to my shop manual the lift capacity is 816# @ the 24" setting.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
