Hello to all. I disassembled my Yanmar 2310 today to replace rings. The rings were bad in two of the pistons. I ridge reamed etc. and am going to be ordering parts. This is my first time at this and I would like some advice from those who have done this.
First, the sleeves look ok although I had to ream the ridges. How do I check ring gap to make sure I do not need to go ahead and replace the sleeves?
Second, two of the piston have some skoring on the sides. Do I need to replace the pistons?
Third, I am taking the head to the machine shop, what should I have them do to it?
Fourth, When I pulled the head the thid piston was at the top of its stroke, should I reassemble it this way.
fith , what is the procedure for checking the valves (after top dead center)?
Tourques:
Pistonrods?
Head bolts and sequence?
oil pan?
valve cover?
I know this is alot of questions but I sure need it to go back togheter ok and need the tractor on a daily basis.
Thanks .
Jim
Tourques:
Pistonrods?
oil pan?
valve cover?
Thanks .
Jim
