WillaminaOR
- Joined
- Aug 1, 2007
- Messages
- 22
So I over heated my tractor and it's not running right any more, I went over this a bit in a previous post. Now I am trying to remove the head to see what I broke and have everything removed I can see to remove and it's not coming off. The only other things I could remove are the two large head studs which I figured I could leave in and there are two small allen head things right in the middle which I figure are core plugs or something and probably aught to stay. The only thing I can think of is the head studs are corroded into the head so the head won't slip off over them, is this a common issue? Is there something I am missing? It's loosened enough to break the coolant seal as there is now coolant coming down the sides of the block. I hope I don't have to remove those studs as I think the only way I'm going to get them out is with a pipe wrench.
LMK, TIA,
Bryan
LMK, TIA,
Bryan
