Hydraulic pressure tap
   / Hydraulic pressure tap #1
choffman41
Sierra Foothills of California
Yanmar 2301
I have a 2301D that has an aftermarket FEL installed. I now want to replace 1 lift arm leveler on the 3 point with a hydraulic cylinder. I'd rather not tee into the supply line to the FEL if I can avoid it. Is there a source at the rear of the tractor that will supply high pressure to run the cylinder?
   / Hydraulic pressure tap #2
choffman41,
If you click on the following link and read the discussion from several months ago, I posted some information regarding adding remote hydraulics to a YM2310D using the tap ports on the hydraulic block beneath the seat. The YM2310D is the shuttle shift version of the YM2301D so I would expect that you have the exact same hydraulic setup as mine.
http://www.tractorbynet.com/forums/yanmar/43657-remote-hydraulics.html
Since this original discussion I added a ROPS bar to my tractor and this provided me a convienient place to add a mount for the quick disconnects. The following are pictures of the remote hydraulic installation on my tractor.
John_R
Thanks John, that helps a lot, however, mine has a short hose that seems to connect the I port to the O port rather than having plugs in it. I don't understand what that's about, but I guess I can just pull the hose and use the existing fittings.
2013 WABASH 53x102 DRY VAN (A53426)
2013 WABASH 53x102...
UNUSED AGT MXCRT23 STAND ON SKID STEER (A51247)
UNUSED AGT MXCRT23...
UNUSED MOWER KING SSRC72-72" HYD BRUSH CUTTER (A51248)
UNUSED MOWER KING...
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
2022 CATERPILLAR 259D3 SKID STEER (A51246)
2022 CATERPILLAR...
2014 Ford F-150 Pickup Truck (A51692)
2014 Ford F-150...
